Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Stickwise you want will preferably want one with a twist axis for YAW control, otherwise you would also have to get separate rudder pedals. Elite is the same as Flight Simulator, in that if you get into it you can easily throw money at it getting controllers, and VR, before you come to your senses![]()
Ooooh, if the stick can work with the Deck and Xbox, that would be good. Then I can play FS with it too!
I really wouldn't get into VR since that would require a proper Gaming PC.
