Similar story to me, I was goingto wait for the CSL DD but then the more I read and waited, the more I decided I didnt want Fanatec gear. Specifically the standard QR system sounds dreadful.
£866 for 3 pedal sprints, shifter and handbrake? That's not bad. Wont you get hammered by import duties aswell though?
I did think about getting the Heusinkveld shifter, but its sequential only I believe and wanted H shifter. I ended up getting a 2nd hand TH8A but then after buying it realised it was being sold without the table mount, so had to get a mount from Thrustmaster. I've also ordered the ClixBeetle Pro TH8A mod which was reviewed by SRG here -
I'm loving rally time trials in BeamNG drive. Makes Dirt 2 seem easy!![]()
The metal QR is supposed to be better than the QR Lite but then it takes the price of the wheel closer than I'd like to the Moza and Simagic offerings which, whilst not cheap, ooze quality. The construction on my GT4 wheel is superb. It's all aluminium and carbon fibre with the only plastic bits being the button faces. There's no flex or rattles anywhere even when deliberately twisting and shaking it looking for them...
It was £866 for the pedals, baseplate, shifter and handbrake plus £186 for the VAT and UPS fee at the door. There's no import duty to pay on sim gear. Even with the VAT and UPS fee it came in £100 cheaper direct from Heusinkveld than I could find in stock in the UK.
Plus I've watched a lot of Niels' videos on YouTube and he seems like a good guy so wanted to support them directly.
I've heard the TH8A is good for the money, especially used. I personally really like a good sequential shifter so I decided to go the route of a dedicated shifter for sequential and pick up an H pattern later. Maybe a Frex or the Heusinkveld one if they ever release it.
I'm very impressed with the build quality of the Heusinkveld stuff. It's beautifully made.
I've never checked out BeamNG. I'll have to do that.
It says DirectX Runtime needs to be installed. Have spent 2 hours so far trying to make it work. Have even reinstalled Win11 - having installed 5/6 racing games Via steam so that's another day or so downloading
