I have 2 G7 Neo's and 1 G8 Neo.
Both model variants are crap, especially in terms of hdr the key selling point. Smaller highlights like doors are fulfilling bare minimum hdr specs:
Morocco in 8k follows our journey through this enchanting country. Exploring the streets and markets of Marrakech, Fez, the blue city of Chefchaouen, the Arf...
www.youtube.com
But daylight scenes are just crappy dark, even hdr 400 crap FI32U for example is much brighter. I have seen this hdr demo on real hdr monitors with 600 nits sustained and 1200 nits peak like an Acer X27. It's worlds brighter and has much better colors, compared with this washed out, color shifting va crap.
People who have no idea how good hdr look like maybe thinking the G7 Neo and G8 Neo are good hdr monitors
I have LG C2 42" even this display is overall in terms of hdr brightness much, much better.
The worst annoying problem with the G8 Neo, even with sdr, are the massively noticable scan lines at 240 hz. Every higher saturated color has this white, horizontal cuts. Easily visible. If not instantly visible, you will see them when scrolling.
Very ugly.
The G7 Neo has worse color shift as the G8 Neo. The coating is on both grainy. Yep i have seen the sub pixel shots from rtings. You may assume the G8 Neo is much worse. But in reality same grainy garbage. LG's nano ips coating oder even Innolux aas-ips coating is much better.
1 G7 Neo and the G8 Neo have dust/dirt inside the panel. G7 Neo 7 x 7 mm bright, grey dust spot, G8 2 x 4 mm black dust/dirt.
The other G7 Neo has no dust, but green stuck pixel. Especially noticeable on black without local dimming.
The stand of both monitors is very wobbly. I wouldnt recommend to use these monitors on a adjustable table, without another table, window board or a wall mount for a monitor arm. In order to stop the wobbling.
Also the color shift is very noticeable. Especially in dark mode. Top is dark grey, rest is lifted grey with green tint and silver glow on top of it (ips glow worse, but this ugly glow is much worser).
Otherwise the colors are in sdr mode (without local dimming) barelay acceptable. Compared with ips or oled a complete joke. With hdr they are even looking more awful.
G7 Neo has at low brightness pwm dimming and buzzing noise.
If you have ever seen proper hdr displays or if you ever had ips with much better colors please dont buy this crap. Even for sdr.
LOL:
Innolux IPS vs. Samsung SVA (CSOT):
да ÐдиÑÑей в Ñвоей лиге Ñоп 4к 240hz в кÑпе Ñ mini-Led подÑвеÑкой ÑÑо кÑÑÑейÑий ÑкÑпиÑÐ¸ÐµÐ½Ñ - 12-биÑнÑе маÑÑиÑÑ (68 719 476 736 ÑвеÑов) â Ñедкие и оÑÐµÐ½Ñ Ð´Ð¾Ñог...
www.youtube.com
Perfect example for bad colors on G8 Neo.
G7 Neo has also scanlines:
