- 9 Apr 2012
You are so far off the mark it’s untrue.
No it isn’t untrue.
A PON has 2.5 Gb given to it. If you had three customers on 1 Gb and they all downloaded at 1 Gb the PON would run out of capacity. Clearly BT don’t allow that and would limit the speed right away and also implement QOS but the point is that FTTP is contended and BT as the largest provider is most likely to suffer from it. So it’s not just about “they should just offer symmetrical” there are more considerations than that.
I used to work in the networks team at the red company. Contention is a real issue.
My Warzone ping times are probably a good 10-15ms lower than before too.
