ThanksThat would work but ensure you have a decent air gap between the cement board and timber
So been out and measured up - it's 5" internal diameter outlet on the stove
Currently thinking a 45° vitreous pipe out the back. Short length through the (to be installed panel) with whatever heatproof surround.
Another 45° stove pipe angle. Stove pipe to twin wall adapter then twin wall in the vertical
Something like
First time posting in this thread, have had a stove for 2-3 years but it hasn’t seen much use since we have a very young family.
It’s a 5kw Stovey, they’re not made any more but it’s a nice bit of kit. Good build quality and aesthetic.
We’re semi detached but when I replaced the lounge floor (yet to burn the old one ) I installed a duct from outside to the back of the stove. Glue goes up the chimney.
We’ve never had a stove before or really know anybody with one so not too clued up on best use.
I’ve a lot of untreated, dry timber stock piled in the garage from various building projects. At least 1 ton and have therefore never burned actual logs in it. Just bits of old floorboard (unpainted), off cuts of kiln dried CLS, etc
This burns quite quickly, is there a good technique to burning this type of wood? I was warned not to put too much in the stove at once as it burns hotter than logs so can cause glass to crack? Is that true?
I’ve always struggled with keeping the glass clean, it soots up very quickly, is this my fuel/technique or typical?
The main reason we’ve only used it a handful of times each winter is the fear of the kids (4 kids all 6 and under) burning themselves. Does anybody use a stove with a young family? What’s your set up?
Hoping the stove can shave a fair chunk off our gas usage this winter!
Cheers.
In short runs, like single storey. Straight up is better, it removes most of/if not all the offset, so the draw is better. Its usually cheaper, as you dont need as many brackets, telescopic lengths or 45 degs etc.
Also, although its hung using a rafter support, a lot of the weight can transfer down to the stove. What you do have to watch is, if the stove isnt a good enough anchor, that the system pivots at the roof bracket in high winds. In short runs, this usually is not an issue.
Looks nice dry stuff! How much are you paying for that?Also i had this lot delivered a week or so ago from my usual guy, need to get it stacked up in the log stores now.
Also is that a some kinda narrow gauge rails?! Handy for hauling wood around if you have something on it!? #jealous![]()
The telescopic is just an adjustable length, it wouldn't be needed if you go top exit and through the roof, but on your first diagram it would be between bend 1 and 3.Brill, thanks
Will take a look at what's needed and get a shopping list together
Do you have to use a telescopic length? And what situations are they used in?
Any suggestions / recommendations on suppliers ? (Or any to avoid!)
Cheers
Like any product there is a certain level of build quality, on Tw this is the seam welds, and end caps/lock system. But really most of TW cost is fit and finish. If its showing a brand name, so that you can look up the certification/documentation for distances and fitting etc, its usually ok. If its something that's unbranded or hard to get core details from the manufacturer rather than the seller its probably one to avoid.
They said the difference was mostly warm up and cool down times.You got to be doing something very very wrong for a cast iron stove to crack.
Although running one too hot may do it, or just having a crap quality one to start with.
My Morso (cast iron) retains heat for ages when I shut it off, but that said, it does take a while to heat it up in comparison to a steel one.
