They are great. For such a small looking thing it powers through huge coins.I've got a similar log splitter, a very very good bit of kit.
Personal consumption. That's my brother with me and he has a stove too.Now that is what you call "Man Tools" - Is all that for your own use or do you flog it. ?
 But hopefully it'll hold up!Nice build.I built a log store from scratch last week, thought I'd share the build here!
I built a log store
Took on a project the last couple of weeks which was supposed to be pretty basic, just popping some posts in the ground and some plywood on top, but after googling custom log stores I had to put in a bit more effort. The frame was made using 3"x3" fence posts, secured to the ground using...forums.overclockers.co.uk
It's put to shame by the scale of @john_smith 'sBut hopefully it'll hold up!
AwesomeGot an install date of second week in November. Looking forward to it getting done. First step in decorating the living room.
Cleared the woodburner out before the sweep comes tomorrow
Before
After
I was thinking about you on the weekend -- I have a set of needle nose plyers that are gummed up. They are my "favourites" - haven't used them for decades. How would I go about cleaning them? Soak them in something?This is why I made a kindle splitter - Cleaned my axes up - was hoping rubber handle one was Estwing but upon cleaning handle on end I found "made in Taiwan" - The other one is a Elwell and reused old handle although has a chip out of the end.
Pretty certain they are pine conesAre those pine cones or acorns?
I am not a expert by any means -Best bet is go on Youtube and look for refurbishing hand tools -They use rust remover - or white vinegar and soda -just depends.I was thinking about you on the weekend -- I have a set of needle nose plyers that are gummed up. They are my "favourites" - haven't used them for decades. How would I go about cleaning them? Soak them in something?
ISAS.
Cones burn well quickly but we don't have any around here.
Also if you change your fire bricks you can buy it in sheets and cut it with a hand saw - One side of mine cracked so while I was at it I cut a new one for each side and back -they are now sitting on shelf in garage ready.
PS - You did read the acorn thread ?![]()
l
