Thanks for those links ..It doesn't, there's no port on it. I've read the manual.
That said,
The Pico 4 is an all-in-one VR headset that can be used as a standalone device or paired with a PC. The Pico 4 is incredibly light and comfortable. The device has a 4K+ display. Pico does not require a social media account to use the device. Games and apps can be accessed through the Pico store and the SteamVR store.
LCD display
97 degree horizontal fov
1x USB-C 2.0 cable + adapter <<< If it uses bloody USB compression like the quest2 I'll not be buying it
btw, so we know for sure this can pair with a pc wirelessly right away? - I saw the link for the adapter so thats just for the cabled hook up? - I assume this will be compression since I assume it will use that usb c connection? - seems like the pico 4 will be much lighter and smaller but the specs are deceiving when compared to the quest 2
https://www.meta.com/gb/quest/products/quest-2/tech-specs/
(some info)
(compared)
I notice they didnt list the price for the pro and seems like thats still in the works ... I was hoping to see a price for it so meta would be 'smart (give me it cheaper)' then the 1500 that is suggested.
