I don't know how to find out what most people are using.Are most people running stable or beta software?
WhyOne thing I wish is they had put a cover over the SD slot
What dock/adapter are you using?How do you change the desktop resolution when docked to an external monitor - can only get 1024 x 768?
How often are you looking at the SD slot.Doesn't look as clean
Because I remember with an old windows tablet I had somehow it got ejected and I lost the card, and since a 1tb card isnt that cheap id rather have a cover to protect that, probably not likely to happen but just saying
You could always go high tech and put a small piece of electrical tape over the opening when the card is insertedBecause I remember with an old windows tablet I had somehow it got ejected and I lost the card, and since a 1tb card isnt that cheap id rather have a cover to protect that, probably not likely to happen but just saying
That is exactly what I was planning onYou could always go high tech and put a small piece of electrical tape over the opening when the card is inserted![]()
Probably might get one by the new yearhow long do you think i would need to wait if i reserve one now
