I just thought it was ironic that all the things you said about the 12900k can be applied to Zen 4.
But leaping out is the fact the high end the Zen4 cpu is often well above 30% extra performance within the same power budget
CPU temp isn't the complete picture. Rip the cooler off a 5600x, temps go to 100c. Has the room got any hotter?so, the air coming from the back of your pc isn't warming than the air int he room? how big is the room your pc is in?
Obviously, people are exaggerating and making it like a meme.... since AMD users used to claim how cool the chips run.
Even spiders seem to notice the wall near my pc is warmer than the rest of the room
You'd expect that though being on TSMC 5nm vs Intel 10nm.But leaping out is the fact the high end the Zen4 cpu is often well above 30% extra performance within the same power budget
As others have tried to explain, the heat of the air coming from your PC is not directly related to the temperature of a thermistor in the middle of the processor. It is only related to the amount of power that is being used by the components in the PC, including the CPU. This is pretty basic physics.so, the air coming from the back of your pc isn't warming than the air int he room? how big is the room your pc is in?
I agree that "95c is acceptable" seems quite the switch around. I guess we just have to get used to it and adjust our fan (or pump) curves accordingly.
But it is the power that makes the room hotter.
But that entirely has to do with the motherboard and not the cpu, doesn't it?Yes, I've done it many times, for you even, in the same way that a power supply is not a 1:1 of what the system is pulling vs what the PSU is pulling at the wall, there are efficiency looses in the components and circuitry, so a CPU pulling 242 watts at the socket is pushing a fistful more watts at the power rail.
Because you are comparing it to last gen instead of it's actual competitor that comes out in a few weeks? I mean if raptor lake launched 2 days ago, would you be comparing it to the 5950x and claiming efficiency and performance wins? No, that would be dumb since zen 4 would be right around the corner. Well...But leaping out is the fact the high end the Zen4 cpu is often well above 30% extra performance within the same power budget
Because you are comparing it to it's actual competitor - because it isBecause you are comparing it to last gen instead of it's actual competitor that comes out in a few weeks? I mean if raptor lake launched 2 days ago, would you be comparing it to the 5950x and claiming efficiency and performance wins? No, that would be dumb since zen 4 would be right around the corner. Well...
So you agree the 13900K is the space heater, you dug that one yourself.
Another quick question please.
Safe to assume a 1kW PSU is good for a 7950X with a future RTX4090?
Ta
The 7950X has a TDP rating of:
170 watts to 225 watts boost
Maximum tested power consumption is 226 watts
The 12900K has a TDP rating of
125 watts to 242 watts boost
Maximum tested power consumption is 260 watts
All that's fine ^^^
AMD claimed Zen 4 is a more effient architecture than Zen 3.
At 120 watts the 5950X scores about 26,000 in R23
Locked to 65 watts the 7950X scores between 28,000 and 31,000 depending on whose review it is.
At the same wattage the 5950X scores about 15,000, half.
That's nothing short of amazing efficiency, a 12900K can't even do that at 300 watts. He has no right to bemoan AMD's architectural claims, its wilful ignorance, unlike a lot of others he hasn't even done any apples to apples testing for architectural efficiency.
I would question why you want to spend £300 on a motherboard.Can anyone recommend a motherboard from the £300 range. My 3770K is due an upgrade.
I was leaning towards the Asrock X670E Pro RS because it has PCIe 5.0 to future proof as I don't upgrade often.
that's 30 seconds of my life I won't get back. Jeez
