Thanks, I think this is the way forward. Even performance limited it will give me what I need which is a short term upgrade from my 4790k with room to upgrade everything later down the lineAbsolutely
Could just reduce the temp limit in BIOS or even leave it in stock.
These chips are very intelligent about how they reduce the clocks when hitting temp limit, no dumb throttling.
Would be interesting to see if CO and additional boost clock could be tweaked to make it boost like 7950X.7700X
@Bencher - Ryzen Master Tool available for download with 1 click application of 65W ECO mode in Windows.
Puget Systems results are always accurate and they don't play games with their results, one of the very few places I respect for real world results.Never trust anywhere that uses % terms always looks like a bigger increase than it is
Anyone know if EXPO ram is needed for AM5? Got Kingston 6400 kit coming and not even sure if it's ok, or even if it's on any QVL for that matter.
It should be here.Where? the one on the download page is still 2.1.0.218
Does that include needing to set a long list of the sub timings or is it just the main ones like you see on the sticks?None EXPO works but you will manually have to set it up in the BIOS, automatic profiles won't work.
We have also found some none EXPO will want to run 200MHz slower than where you set it.
Kingston seems to work fine however.![]()
The reviews have been excellent, for Ryzen 7000 series at least, Dave.
7700X because of the 1 CCD, so pretty sure 7800x will be 3d to get max gaming results
It should be here.
I think it might stretch its lead a little with the 4090 / 7900XT
Going by Intel's gaming slide the 13900k looked barely faster over the 5800x3d and they had it on ddr4 at 3200mhz . And Intel's lower sku are only gonna be slower that's even before talking about 3d zen4
7950X straight in at No1.US site...
7950X straight in at No1.![]()
