You dont care that actual users in here are faking benchmarks to promote one cpu over another?It doesn't matter, both these CPUs can handle the game under the conditions tested, in each review I've seen so far.
He is indeed gpu bottlenecked, but fun fact is he used different settings between the 7700x and the 12900k to pretend like 12900k does worse. Who he is trying to fool, i dont know. Why he is doing it, dont know either. But amd fans... what can you do
Wow your a weird oneYou dont care that actual users in here are faking benchmarks to promote one cpu over another?
Awesome your 12900K RTX 3090 is 52 FPS faster then my 12900K rtx 3090. My system is borked I guess.
No more plastic straws wrapped in paper. Just paper straws wrapped in plastic. Pure awesome.
Welcome to our resident fans of CPU vendor B.Wow your a weird one
Im sorry but not only your benchmarks were fishy as hell, you didn't even share your settings so we could reproduce them. And then you went ballistic defensive about it. If that's not suspicious as ***fully star out swearing*** i don't know what is.Wow your a weird one
Ah really? So you think his numbers were legit? If he had the 7700x scoring 30 fps behind 12900k, wouldnt you be asking questions? Don't pretend im biased when you are the ones that are. That bench was outrageously fake and instead of calling him on it you were stroking your egos. GJWelcome to our resident fans of CPU vendor B.![]()
It's like 4k8k all over again on a new acc with a new agenda, unrelenting..............Welcome to our resident fans of CPU vendor B.![]()
Do i need to pretend like his benchmark wasn't as fake as it gets to not have an agenda?It's like 4k8k all over again on a new acc with a new agenda, unrelenting..............
Vendor B?!Welcome to our resident fans of CPU vendor B.![]()
Of course it could just be a mistake, but his attitude after being asked questions about that bench seemed very fishy don't you think.Doesn't seem likely a random forum member is deliberately faking benchmarks.![]()
Yeah but.. Why would he use a different gpu between 7700x and the 12900k and then act like its the same... It doesnt make sense to meYou can just look at the 12900k vs 12900k results to see he's running into a GPU bottleneck. Running Gear 2 with DDR4 and a frequency drop across the board yet the numbers are the same. You don't need to be hardcore into PC's to figure out that's not a good way to show scaling on the CPU/Mem side of things. I assume/hope in some content he produced he's trying to demonstrate what a GPU bottleneck looks like?
That's why I asked him to run the low preset with DLSS off so you're using repeatable setting with a defined preset and doing your best to reduce the bottleneck.
We know that the 3090 maxed out at 1080p can get around 110 fps, and we know the 12900k can get around 150 fps . So the only way for him to score that low is to underclock his card in the 12900k run. There is literally no other explanation for his results.
Funnily enough, he was using a 5.3 ghz all core / 4 ghz E core overclocked to within an inch of his life 12900k, and still I beat him by over 50% at stock...don't you think it's fishy?
EG1. Nvm, I figured it out. He is using max settings on both runs, he changed DLSS from Auto to Quality (that's why it says custom settings), but he is using a 3090 on the 7700x run and a 3080 in the 12900k run. Then he pretends it's the same card and the difference is due to the CPU being the limit. Check around on youtube, 96 fps is the score of the 3080
Did you not see the Intel and Nvidia DLSS/Xess API slide?Vendor B?!
Them’s fighting words!
7950x has taken top spot in the recommended CPU list for RPCS3
Reddit - Dive into anything
www.reddit.com
www.reddit.com
Nice for AMD to hold the top spot for a few days at least, before the 13900k releases.
Can't wait to see Zen4 with V-Cache destroy everything in gaming though, hopefully we won't have to wait too long.
