Covered the soil that was covering the old lawn on the new drive. Plan to kill it off (and then do something proper in the spring).
Definitely part of the plan, the road is very loud though so potentially some box or red robin too.Wildflowers....
Yeah piece of cake. Used them a few times.Did the bloc blind fit easy
Yes. Those pretty much hold up the blind itself.Yes very good fast to fit! did they have the side the side channels
I think it's a film on them, so if that's the case you won't be able too. Saying that a guy I work with has raybns and says the filter is part of the glass, but I'm not sure.Anyone have any clever ideas to get rid of scratches from expensive polarised sunglasses?![]()
Looks good, did the roof not need any strengthening with removing the brick walls contacting the roof?Far from a days work, and far from being a job solely done by me - but we've resized and steeled our gable end ready for sliding doors with triangular pitched window. Vaulted ceiling kitchen will be in this space alongside a mezzanine level set further back to overlook the whole area.
Yep, that low cost area in the Channel Islands where grotty houses come with swimming pools.What are you building by the way? I mean it looks like a hell of lot of work for what looks like *sees fairly close and grotty dorma in background* a low cost area?
