- 12 Sep 2007
Ah nightmare, hopefully third time lucky.
My replacement RMA screen arrived this morning. DPD driver unloaded it on its side from the van. The plastic holders on the box two were broken, the top seal was unsealed and clearly resealed. The box handles were torn…..
And the screen was smashed.
I can’t help but think the universe is trying to tell you something there!My replacement RMA screen arrived this morning. DPD driver unloaded it on its side from the van. The plastic holders on the box two were broken, the top seal was unsealed and clearly resealed. The box handles were torn…..
The protective foam was still on the front and all the stickers untouched.Does sound like you got a return sent out and the person that checked it and repackaged it didn’t do it correctly before it was sent back out, if it had already been opened? Was the plastic film still on the front?
Time to get a 4090 I guess
If you get a male to male 1/4 adapter, you could use Elgato's cold shoe to mount the camera up there and give yourself some tilt flex.Ok i feel like this is a simple answer but my brain just isn't having any of it.
I see the top of the monitor has what appears to be a 1/4 inch female socket for webcams etc. I want to put my elgato face cam up there which also has a 1/4 inch female socket. For the life of me i can't seem to find a short adapter with a few cm for clearance to make it happen.
Anyone help out? lol
48Gbps bandwidth vs about 25 iirc.Does the HDMI 2.1 offer anything extra since it doesn’t use compression?
tftcentral.co.uk
While it's not ideal you could use a dock for power and USB then a separate USBC to Displayport. Still only 2 small cables to get what you need.
Cant argue with that. Tbh I typed it hit enter and questioned why I bothered to post what I did, haha2 cables is bad![]()
HDMI allows me to alt-tab from fullscreen games seamlessly as if they are in window-borderless mode. Whereas DP causes a second or two delay like its shifting refresh rates (although its not). Just my 2 cents. Also don’t know why that would be the case.Yeah but with DSC on DP does it matter?
What are the pros and cons of both connections?
Looking at this section of the review it seems colour depth is the only difference but doesn’t get into the details of comparing 10v12bit?
Asus ROG Swift PG42UQ OLED review - TFTCentral
Designed as a desktop monitor, the PG42UQ is a 42" OLED display with 4K, 138Hz refresh rate, G-sync and monitor-type featurestftcentral.co.uk
