review of the Cablemod 16 pin GPU cables
NEW Cablemod 12VHPWR cables for RTX 4090 RTX 4080 RTX 3090TI
Quick look at the Cablemod cables for RTX 4000 Series. They are available via the custom configurator at cablemod https://store.cablemod.com/configurator/#ca...www.youtube.com
I would like one with a right angle.
i think 2 should be good because thats what corsair are recommending with their recently released 12vhpwr cable
Nice to see DLSS 3.0 in a plagues tale - switching it on jumps FPS by 60% over just rasterised performance.
It needs it, seems pretty poorly optimised all round but it is a looker.Nice to see DLSS 3.0 in a plagues tale - switching it on jumps FPS by 60% over just rasterised performance.
I can see it but can’t select it.Not getting any where near 100 FPS ! I've selected 4k Ultra DSLL Quality and my max Fps is around 85 ... Also I do not see the Frame generation button I have seen others select on Youtube Videos , Any ideas ? I have the latest Driver.
This ^Its not the connectors at the PSU end that are the issue, its the cables. They are good for 150w each. The new cables they are sending out have higher rated wiring.
I wouldn't use less than 3.
Just google it you need to enable Hardware-Accelerated GPU in the main windows settings, Working now.I can see it but can’t select it.
so have u installed your 4090 into your i7 8700K system? what do u think of it? do u think you're cpu bottlenecked?Just google it you need to enable Hardware-Accelerated GPU in the main windows settings, Working now.
Got lucky today - Decided to check the nvidia site at 1400 today for first time since last week, couldn't believe my eyes to see the green "add to Cart" - ordered and got the dispatch email at 1630Happy days!
