For real this time,
AMD Software: Adrenalin Edition 22.10.1 Release Notes
Article Number
RN-RAD-WIN-22-10-1
Highlights
- Support for:
- Overwatch® 2
Fixed Issues
- GPU for image processing option may not be available using Adobe® Lightroom® on Radeon™ RX 6000 series GPUs.
- App crash may be experienced in Street Fighter™ 6 Beta.
Known Issues
- Radeon™ Super Resolution may fail to trigger after changing resolution or HDR settings on games such as Nioh™ 2.
- Oculus dashboard menu and rendered controllers may appear bouncing/wobbly on Oculus Quest 2 with some AMD Graphics Products such as the Radeon™ RX 6800 XT Graphics.
- GPU utilization may be stuck at 100% in Radeon performance metrics after closing games on some AMD Graphics Products such as Radeon™ 570.
- While previewing the timeline in VEGAS Pro™, some colors may appear inverted.
- Chromium-based browsers may experience video stuttering on extended monitors with mixed refresh rates using Radeon™ RX 6000 series GPUs.
- Users may encounter dropped frames during video playback using hardware acceleration on Radeon™ RX 6000 series GPUs. [Resolution targeted for 22.10.2]
- Display may briefly show corruption when switching between video and game windows on some AMD Graphics Products such as the Radeon™ RX 6700 XT. [Resolution targeted for 22.10.2]
- When Vertical Refresh Sync is set globally to Always Off, system stuttering or driver timeout may occur during video playback using Radeon™ RX 6000 series GPUs. [Resolution targeted for 22.10.2]
- Driver timeout may occur using HEVC hardware encoding on Radeon™ RX 6000 series GPUs. [Resolution targeted for 22.10.2]
Important Notes
- AMD Software Capture and Stream features and Overlay support for Clone mode and Eyefinity display configurations will be introduced at a later date.
- OpenGL applications that are 10-bit aware are no longer supported with HDR display capabilities. Enabling 10-Bit Pixel Format in advanced graphics settings is only recommended for use of 10-bit aware OpenGL applications and not required for enabling 10-Bit Color Display Capabilities.
Package Contents
The AMD Software: Adrenalin Edition 22.10.1 installation package contains the following:
- AMD Software: Adrenalin Edition 22.10.1 Driver Version 22.20.19.16 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.12019.16007).
The AMD Software: Adrenalin Edition 22.10.1 installation package can be downloaded from the following link:
By clicking the Download button, you are confirming that you have read and agreed to be bound by the terms and conditions of the End User License Agreement (“EULA”). If you do not agree to the terms and conditions of these licenses, you do not have a license to any of the AMD software provided by this download.
Gracias!
Is it worth trying with 'Resizable BAR' toggled in the BIOS (off if it's already on, or other way round)? Just trying to think of anything you could try changing, as I'm out of ideas otherwise. Sorry.
