- 21 Jul 2005
- Officially least sunny location -Ronskistats
There's a reason nvidia were pushing the PSU connectors at the start of Ampere..
Damn, when I heard that these things don't need 600w and are actually more efficient than Ampere, I bumped power draw down my list of concerns. I forgot how tiny that connector is vs the 350-450w they pull.
The power itself is "tolerable" but running it through such tiny pins is concerning.
I'm somewhat concerned after seeing those pictures. I have the Corsair cable which is just 2 cables, and while mine doesn't have an aggressive bend it is bent slightly, tried to take a pic of it, not really much I can do as it hits the glass. I'm guessing undervolting might help?!
lol, I do have one next to my desk but seeing it from that angle it doesn't look too good. I might have to take my glass panel off and just have my PC open or something.I'm guessing a fire extinguisher might help![]()
Cheers mate, guess the glass side is coming off tomorrow then so I can straighten it out a bit.According to Cablemod there shouldn't be any bend in the cable at all until after 35mm (1.3 Inch) after the start of the cable.
To me there looks like there is some pull on the top cables, i would do everything i can to make that dead straight for at least 1.5 Inch.
I think it's important to remember that the connectors are where the concern is. The cable itself should bend without much issue. I would rather have the cable leave the connector straight and then have a tighter bend in the cable itself. (where it touches the glass)I'm somewhat concerned after seeing those pictures. I have the Corsair cable which is just 2 cables, and while mine doesn't have an aggressive bend it is bent slightly, tried to take a pic of it, not really much I can do as it hits the glass. I'm guessing undervolting might help?!
Could they not have put a line on the heatshrink to show how far its ok to start a bend from? This whole situation is utterly stupid.
What was wrong with the old ones? they seemed to be doing the job pretty well for more than a decade, they didn't need fixing.
Reddit - Dive into anything
www.reddit.com
more stuff to order , 90 deg angled adapter released on the 30th
CableMod 12VHPWR Angled Adapter – CableMod Global Store
store.cablemod.com
Removed by the (Nvidia) mods...why, one wonders.
