Why is there no prices on the site for the cards .?
Wow. The Nvidia adapters are built very poorly.![]()
The horror has a face – NVIDIA’s hot 12VHPWR adapter for the GeForce RTX 4090 with a built-in breaking poin…
Those who are now beating up on the new 12VHPWR (although I don't really like the part either) may generate nice traffic with it, but they simply haven't recognized the actual problem with the supposedly fire-hazardous…www.igorslab.de
What length did you order?I ordered a 3x8pin - 12 pin 600W cable for a HX1200 from Cablemod and they are back ordered by a fair margin, it says shipping on the 7th November, however I also ordered another one from ModDIY (went with a 2x8 pin - 12 pin 600w), ordered it 2 days ago and shipped it yesterday with tracking (it comes from Hong Kong). The ModDIY site I've noticed also has more options (including cable material type) and different cable lengths (which is what I really wanted) and cost me in total, £2 more than the Cablemod one.
Also just out of interest why did you not order a Corsair one directly from Corsairs website? They do sell them. https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/12-pin-GPU-Power-Cable/p/CP-8920274
. (I have a Fractal Define 7 XL and current cable doesn't touch the side glass panel). Edit: Actually just checked it just touches it.![]()
Ahh I see. Yes I was also wondering over length, guessing 50-60cm should be enough to be safe in larger cases like the Phanteks P600S.That one isn't rated to 600w, I actually have one of those but that was for the Founders 3080 and 3090, the 600w for the 3090ti (and now 4090) was out of stock. I ordered a 40cm cable but I'm starting to think now I should have ordered a 50cm. (I have a Fractal Define 7 XL and current cable doesn't touch the side glass panel). Edit: Actually just checked it just touches it.
RX 6xxx series used the standard 6+2 pin PCIe power connectors - AMD has yet to use the 12-pin.I find it hard to believe AMDs last gen had the 12 pin and they didn't plan on using it this gen.
It supplies the required 600w with the corsair lead , each 8 pin on that cable is rated for over 300w ( about 340w each )What use is that with only two 8-pin connectors?!
Because you have to ground those 2 to have full 600W available. So in abscence of communication with psu, nothing else is needed.I wonder why every cable maker cut the 2 sense pins?
And what would happen if someone connected a fully wired cable.
Yes I know that.
But what happens when I buy a new PSU and it has a fully populated GPU cable.
So 2 extra sense pins, that are wired up and not cut.
Yes I know that.
That must be the “one person” arknor said had the problem!
