Because new spec psu’s are in super abundant supply. Seasonic ones aren’t out until December, and I’m not buying Thermaltake crap.then they should have done their research and bought a new spec psu that doesn't need the adapter lol
Let me repeat that again..It is a specialist custom cable, of course it isn't going to be super cheap. It is still however significantly cheaper than having to buy a new PSU.
Repeating it makes zero difference the bad logic of your statement. If there is no need to upgrade your PSU then why would you spend all of the extra money on a PSU when for 20% of the price you can make your existing PSU work perfectly fine? The cheapest ATX 3.0 PSU with 850w that would be the minimum recommended for running a 4090 is £160, five times what the cable costs. Ideally, anyone upgrading to a new PSU should be getting 1000w+ and those cost £190+. https://www.overclockers.co.uk/pc-components/pc-power-supplies/atx-3-0-power-supplies?sort=price_ascLet me repeat that again..
It costs 25% of the value of a good quality PSU.. that SHIPS WITH ITS OWN SET OF GOOD QUALITY CABLES
And there's something in between super cheap and unreasonably pricey
Where do you buy good psu for $120 nowadays(and thats for the more expensive 4x8pin)?Let me repeat that again..
Anyways it's a statement on value perception, not that you would go around buying PSUs to replace cables, you could even choose to not buy one
Check whats your gpu power saving mode. They wont stop spinning in max performanceafter updating to 526.47 WHQL there is no zero rpm mode,fans are spinning constant on 30% while im not touching pc ,could it be related to a driver?
Yeah sadly it's looking like a long delay unfortunately.I ordered mine 2 weeks ago and have a dispatch date of Nov 6th, so I’m guessing a long wait for those who’ve ordered in the last few days.
Just checking my Cablemod order (Still processing lol) however they've put a notice up now to say since the release of the 4090 their orders have increased 400% fold!
Hardly surprising given what's going on, They should be thanking Nvidia for ******* up with the adaptor cable.
So expect a delay with your orders guy's, One guy said his is still processing after 1 week with an estimated ship date of around 19th November I think it was.
Hope that isn't true it might have been quicker waiting for a decent quality new PSU if the delays are this bad.
It's a statement abt value perception I am not going to buy either the psu or the cable. It's just put up there as a benchmark.. to reject the consideration altogether, logic dictates that we should even consider the no deal outcomeRepeating it makes zero difference the bad logic of your statement. If there is no need to upgrade your PSU then why would you spend all of the extra money on a PSU when for 20% of the price you can make your existing PSU work perfectly fine? The cheapest ATX 3.0 PSU with 850w that would be the minimum recommended for running a 4090 is £160, five times what the cable costs. Ideally, anyone upgrading to a new PSU should be getting 1000w+ and those cost £190+. https://www.overclockers.co.uk/pc-components/pc-power-supplies/atx-3-0-power-supplies?sort=price_asc
Where to check in NV panel?its maximum performance
I think you are the one who is missing the value perception. You sound like 30 dollars is a lot of money. But its not 1999 anymore, 30 dollars is nothing. You will barely buy a pastrami sandwich for that in NY for example - or 4 donuts in London.It's a statement abt value perception I am not going to buy either the psu or the cable. It's just put up there as a benchmark.. to reject the consideration altogether, logic dictates that we should even consider the no deal outcome
Nvidia recommends a 850w psu though, so i would say you are just embellishing beyond what you have written.
Then use autoIm not by pc now,but im pretty sure i dont have option optimal,just prefer maximum perfomance and auto
I literally wrote that 850w is recommended so wtf are you talking about:Nvidia recommends a 850w psu though, so i would say you are just embellishing beyond what you have written.
However if you are buying a new PSU why on earth would you buy only the recommended minimum wattage for the current gen? Anyone with any smarts would buy a PSU that give you some headroom for future potential increased power requirements.The cheapest ATX 3.0 PSU with 850w that would be the minimum recommended for running a 4090
