- 22 Mar 2017
- Poland
Oki thank you for helpingWill be perfectly fine and a good PSU.
Sure, although I'm not sure we can go much higher?! Will the next gen cards have 2 new connectors?? 1200W in one card would be impressive. At this point I almost want Nvidia to do that just for comedy value.However if you are buying a new PSU why on earth would you buy only the recommended minimum wattage for the current gen? Anyone with any smarts would buy a PSU that give you some headroom for future potential increased power requirements.
Your whole order should have come to around €43 , basically around £23 for the cable around £12 £or delivery and import fees from China ... €18 euro for international dpd shipping with customs fees paid is not a rip off at all .They are ripping us off.
18 euros for delivery!!!!
And I won't get it till near the end of november.
I had to wait about 2 weeks for my cable and I ordered it before the 4090 was even released, apparently their orders have increased 400% now so can kinda expect some delay. If your not happy then best option is to cancel and try get one from your psu manufacturer.
OK it's a rip off in your opinion.Yes it's a rip off.
I told you what I paid, so don't lower the cost.
Sounds like you work for them.
Told everyone I know know to stay clear.
So £38.76 all in and that was for a 4 x 8pin if I remember correctly? Apparently these prices are made up on a whimI order mine as
29.90 euros for the cable
15.00 euros P&P
Total 44.90 euros.
Does anyone know what the reg number is for Jenson's private Jet? We could confirm if he did actually travel.
I don't have much confidence in the continuation of ATX 3.. but if you are buying one it would actually make sense to get a psu with 2 12vhpwr ports. Currently that's only available from thermaltake, which isn't a prefered brand... by 2026 you may have cards that could use bothSure, although I'm not sure we can go much higher?! Will the next gen cards have 2 new connectors?? 1200W in one card would be impressive. At this point I almost want Nvidia to do that just for comedy value.
4 x 8pin. the 3 x 8pin was the same price so your choice. But yeah their prices seem to be all over the place once demand shot up!So £38.76 all in and that was for a 4 x 8pin if I remember correctly? Apparently these prices are made up on a whim![]()
Cablemod cables are well made as I've had a few of them, bought a 24pin,cpu,two pcie all has capacitors built into them, not seen any other company do this.
