sounds like a lot of over hyped doom mongering, mostly from people who don't even have a 4090Blow this for a game of soldiers. I’m off to buy a 3090ti or might wait to see what AMD delivers. So glad I avoided the initial hype of the 4090. Sounds like a stressful and uncertain outcome.
It seems project fear around covid was so successful it has hijacked people's brains and taken away their ability to perform basic functionality
are you suggesting gaming enthusiasts that would be amongst the first tp own a 4090 have zero online presence and would be totally unaware of this happening so wouldn't chime in with their own experience?
If Nvidia want to send me a better cable though I'm all for it, certainly not sending 40 odd euros to scaremongering for a sale cablemods
yea and he since did a video where he tried to get a cable to melt and it wouldn't so who cares....
The people who think it's an issue are clearly jealous of anyone who owns a 4090
Awesome, I feel your pain concerned fitting it in with watercooled stuff , I had to bend a new pipe for the rear rad so I could actually fit the gpu in place ... its less than ideal running an air cooled card in a watercooled rig but is what ir is until EK pull their finger out and make us some blocksOrdered.
Hopefully it fits without having to re-position my pump/res combo. It's already going to be a massive headache to drain loop & re-jig the glass tubing.
so how many cables did jay2cents etc melt again whilst trying to cause a failure? the only thing melting seems to be peoples brains.
Well yeah if you sent the card back without its original cooler can understand them turning it down but surely as long as you present the card to them in the condition you bought it new then how would they even know its been opened if no identifying stickers.actually any removal or modification of cooler void warranty. they don't use stickers, because you could just easily find them online and then just put another one
youtubers couldn't make it happen but apparently they are death-traps that will spontaneously combust your PC, even whilst idle with 35watts flowing through the cable
we're entering urban legend territory now
how many died within a month of contracting covid? rather than by actual covid it self.Explain project fear to the 6,589,972 people that died.
I dont know how to solve constant 2610mhz clock/60-70w,while card is in idle (Strix),tried in NVCP both normal perf. And maximum perf. All same,did DDU with a latest driver all same,all without msi afterburner not present on the system because with afterburner installed im loosing zero fan rpm and fans are working constant 30% 1000rpm,i have only one solution left, roll roll back 522 driver,any thoughts?
Maybe wrong thread
)12 wires going to the socket, we have the proper versionI would never soil myself to post on reddit. However I would post about it on here
I ordered one before any of this fuss about the nvida adapters
Mainly because it will now match all my other cablemods cables in my PC plus I like the neater way of the join being closer to the PSU and its just 8 wires going to the socket on the gpu.
If it is worrying you that much mate best option would be to leave the side panel off and make the cable as straight as possible and make sure to have a lint free cloth close to hand to dust down the pc each day with the side panel off as if its anything like mine it loves to attract dust with the glass side offWell I thought I was safe with the Inno3d 3 way adaptor as I noticed a familiar pattern as it seemed to be only the 4 way adaptors affected however someone's MSI Trio has also burned which is a 3 way splitter so bang goes that theory literally (Sorry that was a crap pun)
I now have to wait probably a month for my Cable to arrive from Cablemod so what do we do.
Keep unplugging it everyday and checking before it does damage to the GPU and in which case is shortening the life of it anyway but then I don't care as it will be getting tossed out once my new cable arrives but then there's the risk of it happening for sure if I keep unplugging it and reinserting it.
At this rate I can see me getting a new crappy PSU just to have the cable direct to PSU from a crappy brand that's only available right now.
Decisions decisions and it's becoming expensive ones at that, First the cable then the vertical mount and now maybe a cheap ass PSU to tide me over.
Believe me mate if it wasn't for the little lad I would have left the panel off and attached some sort of brace to the cable near the plug end to keep it straightIf it is worrying you that much mate best option would be to leave the side panel off and make the cable as straight as possible and make sure to have a lint free cloth close to hand to dust down the pc each day with the side panel off as if its anything like mine it loves to attract dust with the glass side off![]()
Not having this issue on the Zotac , currently at idle and clock is 210Mhz with temp at 40 deg and fans at 0% , gpu using 30w and am on latest driver with Windows 11 2H22. Are you using the latest beta version of MSI afterburner or have you tried Asus GPU Tweak 3 ?I dont know how to solve constant 2610mhz clock/60-70w,while card is in idle (Strix),tried in NVCP both normal perf. And maximum perf. All same,did DDU with a latest driver all same,all without msi afterburner not present on the system because with afterburner installed im loosing zero fan rpm and fans are working constant 30% 1000rpm,i have only one solution left, roll roll back 522 driver,any thoughts?
Maybe wrong thread
