Nope I'm afraid I can't make it out, why would it be an issue?Not sure how you can't see it, plain as day here, the rest of the connectors are fine, the one circled has an obvious horizontal split\crack at the top.
I put a thermometer in the bottom of my case earlier to see how warm it got lol... I'll do it again , play cyberpunk for a bit and take a picNvidia 4090 SP-ARC edition - Helping to keep computers warm since 2022....
Now with Crispy 3.0 cable mods!
I put a thermometer in the bottom of my case earlier to see how warm it got lol... I'll do it again , play cyberpunk for a bit and take a pic![]()
, I Think my noctua case fans are set to run at around 60% at 55c cpu tempHeat rises smarty pants so a normal thermometer needs to be moved around
and the results after 30mins of cyberpunk @ pyscho 3440x1440
Nice and warm even in the bottom corner, I Think my noctua case fans are set to run at around 60% at 55c cpu temp
yea but in a case the fans shift the are outside pretty fast so the top part of the case generally seems to be the coolest.
if you have a 4090 do some gaming and then put your hand near the side of the card and then move it up in your case and you will feel the heat spot is all around the card
But he didn't care about it and said kids make more noise so they drown it out.. I could hear it and it annoyed me as I could hear it over the case fans at a high speed and the fans on the card running pretty quick too.As per previous posts, latest reports suggest that the problem is the 4x 8-pin adapter shipped with the cards.
Which raises one question - some AIBs (e.g. Inno3D) seem to ship with a 3x 8-pin that looks very much like the 3080Ti one. Are those affected too?
yea but I struggle to hear it unless I open my case and get ear level with the cardDoes your 4090 suprim x coil whine too ? Seems a lot of people have coil whine with these and I tested one too at a work mates and his whined too like a bee hive.But he didn't care about it and said kids make more noise so they drown it out.. I could hear it and it annoyed me as I could hear it over the case fans at a high speed and the fans on the card running pretty quick too.
hardware unboxed still has a fanbase after what happened?
What happened?
Steve is frequently fighting with and insulting people on Twitter
