- 17 Mar 2017
- Manchester
Aah that explains it cheers, I didn't know that, Hopefully we don't get the stuttering that happens in some games with Gsync on and Vsync off then with DLSS 3 titles.As far as I've read, v-sync is NOT supported with FG at all, by NVIDIA. Yes, you can force it in drivers, but it causes horribly high latency:
Nvidia DLSS 3 Analysis: Image Quality, Latency, V-Sync + Testing Methodology
Nvidia's new DLSS 3 frame generation technology increases perceived performance to remarkable effect - but it is a first-gen effort with key improvements to ...youtu.be
That includes limiting frames in other ways as well. This apparently (as per few other testers) also includes g-sync, which doesn't seem to be working.
I also have a Zotac 4090 ( needs to be rma , bad fan ) and that will boot up perfectly and will display the F2 to enter bios with the rog logo , new one does none of that . Any idea whats going on here ? I9-10900k on an Asus Z490 Formula XII Motherboard ... The new card itself seems to be a good one as from the short bit of testing i have done seems to boost as high as my zotac does which is around 3150Mhz and the memory seems to overcloack just as well , it does have a bit or coil whine where the zotac had none but had a noisy fan to make up for lack of coil whine
Just trying to sort out this issue why it wont display on bootup as currently the only way to enter bios now is through Windows recovery setting
