AMD has done very well this time to hide performance. They have pulled an Nvidia and not provided AIB's with working drivers until tomorrow, so AIB employees can't run benchmarks and leak performance.
ok cool.More than likely same here.
Thats thanks to the new renderer called Gen 12 that is planned to be fully added into the game within the next 3-6 months
Do you know any games coming out on the horizon that is deemed the new "Crysis/ flight sim" game that would require a 4000 series and beyond?
What time does your cod comparison NDA lift mate?
I'll probably go for AIB RDNA3 in whatever form that takes. My GameRock 4090 is pretty fast, so will need a suitable counterpart to lock horns with.What time does your cod comparison NDA lift mate?![]()
He said 8 pm UK time.Ah, so 4am here then. Guess I’ll catch the news in the morning when I get up!
Not really. Anything I am interested in will not be any more demanding than Cyberpunk 2077 and I can run that 60fps just fine. It is Unreal Engine 5 games that may require more grunt. But by the time they start coming out 5000 and 8000 series cards will be out anyway, so no rush whatsoever.
Yup, just another marketing tool these days.Yes, goes to show "leaks" are more than likely managed rather than simply accidents.
Since AIB really do need to know the actual power output, do AMD/Nvidia give them a power-virus driver (no real performance but it gets hot), or are the expected to make their own heaters in the exact shape of actual die?AMD has done very well this time to hide performance. They have pulled an Nvidia and not provided AIB's with working drivers until tomorrow, so AIB employees can't run benchmarks and leak performance.
I think that's not been the case for some time. Maybe if you play very old games or emulated stuff it might be true. I have for instance, had a lot more trouble with multi monitor on my 3060Ti than on my AMD cards where it "just works"If the AMD drivers were decent, I would not hesitate, but they've been the reason I've avoided AMD for over a decade. If the drivers were as good as Nvidia, then the 7900XFX should match the 4090. But more importantly it would be worth the price.
drivers issues hasnt been case for ages now
Tom Howard quote there, not a good example of something actually working as it should lolI think that's not been the case for some time. Maybe if you play very old games or emulated stuff it might be true. I have for instance, had a lot more trouble with multi monitor on my 3060Ti than on my AMD cards where it "just works"![]()
So mostly re-launched older games with an RT mode tacked on?What about when overdrive RT mode lands![]()
But there isn't a lot on the horizon tbf, most of the main ones have been pushed back to later next year. Only things that come to my mind which I'll be playing is the above +
- portal rtx
- plague tale requirem when its RT lands
- avatar 3 but that's late next year
- witcher 3 remastered but will no doubt get bored after all the waffling
- atomic heart in Feb.
- black smith wukongnext year
- starfield next year
Hence why I'm in no rush either.
