- 8 Jan 2003
- Scotland
You have the AMD fans, the people on the fence, and then the nVidia fans that pretend they were interested but never were.There is such a wide disparity of initial opinions!
Hold on, those were non RT numbers.
So,
vs
So, to make it simple. 4090 does about 42fps native, vs 7900xtx (if would be double 6950xt), 26fps +/- .
Ouch. So much for good gaming for "years to come".
Probably lower CPU overhead than the 4090.It is me or the 7900XTX is getting way higher fps in Valorant than a 4090.
AMD is claiming 704fps at 4K but a 4090 is getting around 550fps at 1080P settings in this video:
What is going on here??? Is it really faster in Rasterization than a 4090 for a much lower price??
Yes but people making out it’s just GPUs, when it’s everything.Except wages of course, they remain low.
Not appreciable soThe 6900XT had less tflops than a 3080, but was faster in raster!
Nvidia cards face a driver overhead issue at lower resolutions resulting in a CPU bottleneck which gets eliminated at higher resolutions.It is me or the 7900XTX is getting way higher fps in Valorant and Apex Legends than a 4090.
For Valorant, AMD is claiming 704fps at 4K but a 4090 is getting around 550fps at 1080P settings in this video:
The 4090 gets around 220fps at 4K in Apex legends.
The 4090 does seem well ahead. Confuses me as AMD said its the most powerful GPU in the world near end of presentation. Just lying?
Tbh the price is not that bad but the RT perf is very bad (at least very bad vs my expectations).
If you can find a 3090 or 3090 Ti less expensive, you can buy that instead, probably won't have the same raster perf but you will have a better RT performance and better support. Or wait for the lower end Ada, probably the 4070 will have better RT perf than RDNA 3.
Is there any reason not to buy a lower end ADA GPU around the same price?
Absolutely demolishes Nvidia in performance per dollar which is what matters to the vast majority of people. I'd say there is a cigar.
Yeah, inflation excuse and the numbers add up. A 1080ti price in today's number would be £825. You make sure to add a tip for AMD when you buy their card..It’s called inflation. Things go up.
The RT performance is actually fairly decent given it will compete with the 3090 series and significantly beat it in raster. At the $1k price tag I would call that a decent GPU. I am waiting to see how 7800XT goes, but at least now I know that it will be a lot faster than my 3080 FE and be a lot less than $899. If I was wanting a decent Nvidia upgrade I was looking at the joke priced 4080 16GB. These AMD 7900 GPUs and their prices have just slapped the $1200 4080 16GB silly.
Yet still we see the AMD = "not good enough" nonsene.
Can be priced the same as a 4070, if a 4060ti is ahead in RT (and cheaper), won't matter. Is the same situation with RDNA2 vs. 3xxx.
That's because people want to justify their near on £2000 GPU purchaseIt is early days and only based on one AMD slide, but a ~50% - 70% improvement in RT performance over the 6950, is right around the 3090 for RT. AMD were never epxected to match the 4090 for RT and now that it meets that expectation, it is suddenly "very bad"?
Genuinely don't see whats to not like here, I know we didnt get any direct benchmark comparisons but the xtx at $999 seems like a steal compared to the 4xxx series so far. at those prices these cards are definitley compelling compared to the alternatives, those CP numbers its an extra $700 for an extra 10fps from nvidia .... no thanks.
No way - that slide was rendered with FSR3!The fact that they are using unspecific upscaling tech and not native raster renders that slide utterly useless.
