Nothing confirmed. Expecting around two weeks
About two weeks later now, any closer to an ETA please? Thank you!
Value is value. If it's offering the same performance as a cheaper platform but charging more, then it's poor value.Of course, it would be nice if AMD would soften their prices before I do that build because it's awkward that I can put together a competitive 13600k system for hundreds of pounds less. Sad news for everyone if that's not going to happen - probably most for AMD. It's tough trying to sell a product for more than its perceived value! The reasons for the cost don't matter, it's how much everyone else can deliver something similar for that has to set your pricing.
240mm AIO on the intake will do great, it is still a 125w class CPU.
My 5800X is cooled by 240mm AIO in a more cramped case. Not an issue as long as it is getting cool outside air through radiator. And I am considering upgrade to 7700X in same Rajintek Thetis case.
A 95W eco mode is of course available for a 7700X, but I don't think anyone's done any really good benchmarking of the 7000s when you put the power limiter on. Will wait a while and hope something shows up. I'm starting to feel like Zen 4 might actually shine when you power limit it, a few have reported better gaming performance because the temps drop and the clocks go up...Gigabyte B650M elite ax?
Although I am in theory happy with a B650, I'm picky and immediately exclude anything that puts an m.2 slot behind the GPU and doesn't provide a heatsink. Been in that situation before, my poor 960 pro was hitting 90 degrees under gaming load because of that placement and lack of anywhere to dump the heat! I think it's the Asrock mATX board that puts the 2nd m.2 down in the far right corner which is very sensible, but then goes on to pair good layout with being the cheapest board with the weakest components.I believe this is eco mode - enforces a power limit (e.g. 65W or 105W) to help keep thermals under control. There's not much hard data around on it right now, but there's suggestions that people only drop 5% MT performance in exchange for a huge power and temperature drop.
On that note, maybe this is the thread to ask; anyone know whether a 7700X can be cooled adequately in a smaller case like this one?
Fractal Design Pop Mini Air RGB Clear Tempered Glass Mini Tower Case - White
Order Fractal Design Pop Mini Air RGB Clear Tempered Glass Mini Tower Case - White now online and benefit from fast delivery.www.overclockers.co.uk
I've had a hankering to do a micro atx build for years, and for once there is at least one good mATX motherboard available so maybe this is the time. I would be willing to consider permanent eco mode if the performance loss isn't massive (and I don't think it will be) and tend to undervolt stuff on instinct. I believe that case could handle a Noctua D15S, or a 240mm AiO - is that going to work out?
Gamers nexus did a good video testing performance of 7950x in 170w tdp vs 110w and 65w eco modes.
Edit - missed that it had been posted already
That's quite ok, I missed the original posting so I shall go look it up now! Thanks for the tip
*edit* Dropping a 7950X to 105W mode and only dropping 300mhz while cutting off 34 degrees C seems absurdly good. The efficiency rockets up with only that modest drop and you still have a 16c/32t cpu![]()
Temp drop doesn't matter, power savings do.
Temperature really only matters when it's causing you to lose performance but that's not the case with zen4; temps are irrelevant unless you are losing performance. Eco mode power savings are worth discussing
But fair, power consumption is what leads to heat generation.
Tbh, I prefer a PC that doesn't heat the room so I tend to think in terms of thermalsBut fair, power consumption is what leads to heat generation.
Either way, it really feels like the 7000 series has been pushed past it's actual 'intended' speed when there's so much efficiency gained by giving up just 5% performance. But I guess that's what happens when all marketing focus goes on the performance numbers. We've been here a few times over the decades but it seems to be particularly savage right now![]()
Set my 7950x to Eco Mode 105w. Weirdly, it performs better than setting the power limit manually to 125w with a negative 10 offset on all cores.
Ah I just assumed 105w limits it to 105w. Interesting. ThanksProbably because setting 125w locks to 125w but the 105w TDP profile actually allows it to pull up to 160w so since the 105w profile actually has a higher power limit it's gonna be faster
