My 4090 GameRock appears to be quite a leaky chip and will easily hit up to 500W in Modern Warfare II campaign at 4K max settings at 1.050v.Its shows what i was referring to in my original comment that the card can and will happily draw over 450w when needed in certain games and you asked if that was based off hearsay to which i am showing you no it isn't . I never said you will get massive gains going from 400w to 600w but you will lose performance in games that need to use more as once you are power limited the core will downclock itself and you will lose performance to a degree . As i put why would i want to cap performance when i am not even hitting the refresh rate ? If you are happy to do so good for you but having a card limited by power is not something i am interested in and neither is the guy who was originally asking about the cable.
