Thanks for this. Couldnt find it anywhere, 18GB pulling down from that link now at 60MB/secMatrix Awakens Demo compiled with new Unreal Engine 5.1
Someone compiled the Matrix Demo with the latest Unreal Engine 5.1 main branch on Github. UE5.1 offers significant improvements such as inclusion of transparent reflections on glass, performance improvements and the integration of DX12 Ultimate.
It runs significantly better in my test compared to the builds before. It also includes a settings menu and DLSS.
Note: You need a DX12 Ultimate capable GPU to run it (RTX 2000, RTX 3000 and RX 6000 series)
Newer compiled version here :- https://drive.google.com/file/d/1eQ_Oav8pxMJ-55qwwyRurjS_dyKgFGqZ/view?usp=sharing
FIX for Google Drive "Download quota exceeded for this file" 1 - Create a folder on your GDrive, leave it empty 2 - click on the link and select "add shortcut to GDrive", then select the folder you've created 3 - go to your GDrive page and right click the "Folder" your created and select "download" Important: DO NOT right click on the "File" to download, instead right click on the "Folder" you created to download.
If you have no folder when you add the shortcut to you GDrive (google drive), create any folder and move the shortcut to it and download the folder not the file and it will download without errors of too many downloaders or exceeded quota.
UE 5.1 City Sample Download | 1st P. | DLSS | Graphic Menu | Cinematic | Vehicles
Has a menu to change settings now too as you will see from above video.
