That's the stuff here :-
Buy Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Pad for £4.48 with Free Shipping Worldwide (In Stock)
www.moddiy.com
See problem now for people that want to water cool their 4090FE/AIBs (guessing AIBs are using PCM TIM too) is they will need to get PTM7950 pads/paste or use liquid metal, reason is this pad/paste is only second best to liquid metal and normal thermal paste can't match it. So heads up to people taking them apart for thermal paste changes as this is not normal thermal paste but a phase change pad/paste. Used a lot in laptops and sensitive equipment that needs heat removing quickly.
Lenovo laptops uses a custom version pad PTM7950 and called PTM7958, Alienware laptops use
Element 31 PCM paste basically a version of this stuff, etc more custom ones too and most highly electrically conductive too depending on the custom versions that have more metals in them like the Element 31, so don't get this on electrical parts like liquid metal. So if you don't know the TIM method used on a device don't just guess it's thermal paste because it's grey and looks like that when removed as that can cause issues later and hot spots. This stuff doesn't weep out (pump out) like thermal paste over time so don't go replacing TIM on a 4090fe/AIBs unless you have new PTM7950 pads/paste version or you want to risk liquid metal.
So you have been warned now and if you replace the paste and wonder why it's running hotter this is why also new cards or PCM TIM change may show higher temps at first few hours until the stuff settles after a few thermal cycles.
This is the paste tube version that can be used too :-
Buy Honeywell PTM7950 SP Super Highly Thermally Conductive PCM Paste for $19.99 with Free Shipping Worldwide (In Stock)
www.moddiy.com
Honeywell PTM7950SP Super Highly Thermally Conductive Phase Change Material (PCM) Paste Thermal Interface Materials
PDF from Honeywell for this stuff :-
Phase Change Materials (PCM) are often used as matrix materials for thermal interface applications.
thermalmanagement.honeywell.com
