Is your stove a wood burner or a multifuel one?So I regret getting nothing but oak, it's incredibly difficult to get going well.
Once we're down to half I'll get some birch as well.
The pallets it comes in is all split up as kindling a surprising amount as well so that's a bonus.
Isn't it just? I made that rookie error last year.So I regret getting nothing but oak, it's incredibly difficult to get going well.
Something very similar to those that I use for my pizza oven.Isn't it just? I made that rookie error last year.
This year I got 50% birch, use a birch to get going and oak goes on once established.
What are you using for fireflighters? I can recommend these: https://www.amazon.co.uk/Natural-Eco-Wood-Firelighters-Kindling/dp/B07FF436N5/ref=mp_s_a_1_1_sspa?crid=2C3C92NQJTPUE&keywords=firelighters+for+wood+burners&qid=1669473983&sprefix=fireligh,aps,111&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfYXRm&psc=1
Although tumble drier fluff and paper are pretty good too.
Blow torch works as well to get the kindling going.
Also popped into the local fireplace showroom and got a quote to install this into the kitchen
Prices have definitely gone up and even I place the order now, his next installation slot is February !
Nice, yeah definitely won't look out of place in a room that size. Should be awesome.
 and can't (but have to) wait !
Took a call from the showroom and there's a delay in getting the stove. Current estimate mid / end of Feb. Current install date 31st Jan. No guarantee on the delivery date
However after a five month wait he has had a few if these delivered
PVR Cylinder Wood Burning Stove
Our PVR cylinder wood burning stove will always be a talking point in a home, with its stunning design and wide fire window.www.charltonandjenrick.co.uk
Purevision 180 degree window and what a piece of (more expensive) kit
Can swap to this one (reserve that stove) and keep the install date, which we decided to do![]()
Amazing stoves, only had chance to fit few due to the cost, but it does come with active baffle and multifuel. Just make sure you familiarise yourself with the active baffle, as only purevision stoves have these.
Heads up to nooby's - We had a wasp in house this morning so beware when you bring logs in and put them in log basket -the heat wakens hibernating wasps and they come out of hiding.
It was buzzing away behind bedroom blinds.
