Bit more expensive but look better made. ThanksLooks fine.
Not sure on the comparison on size / cost but take a look at these too
Log Store - Wooden Garden Log Stores - Rutland County Garden Furniture
Rutland sell a selection of Garden products and have a variety of Log Stores to choose from - click here to view our selection!www.rutlandcountygardenfurniture.co.uk
Would you say this does a particularly better job than the cheaper ones you can get on Amazon?These are good stove top fans, really good customer service too
Vulcan Stove Fan
The Vulcan stove fan is a stirling engine powered fan that quietly and efficiently circulates warm air from your wood stove, coal stove or other heat source, through your home or workshop dramatically increasing the effectiveness of your heating appliance and improving your comfort level.www.stirlingengine.co.uk
Sounds technical. Generally anything bigger than my fingers & thumbs circled I split. So anything bigger than around 6" diameter (I've got small hands).Anyone recommend any good splitting mauls or methods to split logs? Got myself a good size piece to use as a base, but need to start breaking down some of my stash.
What diameter and up do people generally like to split their logs at to use in an open fireplace to maximise heat?
It's a Sterling engine, so quite a lot more technical, far harder to produce (very mechanical), so far more expensive, but also loads more fun. Some of the ones with exposed engines are awesome!Would you say this does a particularly better job than the cheaper ones you can get on Amazon?
Regarding moisture meters, any recommendations? Cheap & cheerful?
Have got access to some broken pallets through work, should see far more of them through winter (busier time) but they'll have been used for loading plants on, so dirty and wet. Then discarded to the side of a loading yard left in the rain etc. I've been given the green light to some 'wrongly sized' ones to build a log store for myself from, but the guy also said welcome to any others to break up for woodfuel as all they do is burn them to get rid of them anyway!
Basically if they're too big to fit on my stove I hit them with my axe/maul until they're small enough to fit!
The cheap amazon ones just use a heat exchanger to generate electric to power a fan. The sterling uses heat transfer to drive a piston that drives the fan.
An Elegant Machine - The Stirling Engine
The Stirling Heat Engine is an elegantly simple machine. Very efficient, the model in this video will actually run using the heat from your hand. YouTube c...www.youtube.com
One of the links above to the 'bay I found they did a 'dual fan' version from, looked quite low profile. Should be able to get height dimensions somewhere. Lots of cheapy options around there and the rainforest and I imagine they're much of a muchness when it comes to quality. They generally have to be metal/alloy to withstand the heat. The exchangers are just a hotplate design with really nothing to go wrong, 2 wires to the fans and then the fan motors are just cheap and probably easily replaceable, or if you could put your own bespoke metal frame together somehow to mount the fans.Ah I didn't realise that it was a bit more 'mechanical'. They look quite cool don't they. Having looked at the clearance on the log burner we may have soon I'm not sure we could fit something as big as this above the burner though. I wonder if there are any low profile versions knocking about.
Sorry for not responding sooner, I have to say it’s the only fan I’ve had, I think we’ve had it over 6 years now its never had any issue until last year when the bearing went but they replaced it free of chargeWould you say this does a particularly better job than the cheaper ones you can get on Amazon?
Arada Holborn 5 Wide-screen has been delayed so been offered a Heta Inspire 45 instead. Anyone know if it's worth it? Or wait.
I actually prefer the more modern look of the Heta the wife prefers the more classic looks of the Arada. Spec wise the Heta looks to be a bit better with a higher efficiency.I have a Heta Inspire 45. Been in for just over 3 years, absolutely no issues. Can't comment on the Arada but depends how much you want that one I suppose.
