- 31 Jan 2022
- UK
Video from Linus today about this stuff I mentioned above.
I wonder if I am the only one who is perhaps more interested in the Asus Noctua graphics cards?
I've seen 750 mentioned a lot.Quick question and I am sure its been answered, what sized PSU would a 4080 need?
Thanks.
Basically if you run the 3080Ti in your sig fine then you'll be ok with the 4080.Quick question and I am sure its been answered, what sized PSU would a 4080 need?
Think I'm going to wait now. MSI and ASUS are all stupid expensive for no real gain and have a coil whine lottery. PALIT has crap PCBs that don't even use fuses for basic safety, and everything else is out of stock anyway. Real shame that the biggest issue with the 4090 is the AIBs. They're either all charging you the value of a plane ticket for a colourful shroud, or scraping the bin for bargin special components.
Oh no that’s not great, I was considering the Palit after reading some good things about it on here over the weekend.
Which AIBs are favourable for the 4090?
Thanks mate.Basically if you run the 3080Ti in your sig fine then you'll be ok with the 4080.
Depends on the rest of your systemQuick question and I am sure its been answered, what sized PSU would a 4080 need?
Thanks.
What's imn my sig plus 4 fans is probably it.Depends on the rest of your system
A 65W AMD CPU with only a couple of case fans and SSDs, no sound cards or sundry powered off the mobo: 650W.
A system with a hefty Intel CPU, 850W. Maybe more if you want to start overclocking stuff and have everything but the sink plugged into the mobo (you still see posts with 8 HDs running and 10 case fans, 2 USB hubs for VR and so on).
Eurgh. I was so ready to pull the trigger on the GameRock OC 4090 this morning now I read the above comments regarding fuses and getting cold feet. I've had coil whine on my 1080 Ti FE since I got it so maybe I should drop the extra money on an MSI. Had their 980 Ti Gaming once upon a time which was nice.
EDIT: found the PCB tear down for the Palit:
GPU PCB Breakdown: Palit RTX 4090 GameRock OC // BIG OOF
Techpowerup review: https://www.techpowerup.com/review/palit-geforce-rtx-4090-gamerock-oc/TL;DW/text version: https://www.patreon.com/posts/73321881My Patreo...m.youtube.com
I own games already that do and there is future proofing.why 16gb though surely 12gb is more than enough? I'm not aware of any games that uses this amount of vram
Here's my Palit 4090 GameRock running Firestrike Ultra. It is currently the fastest graphics score on Firestrike Ultra on the OcuK bench thread, beating out all those other 'superior' 4090 models.Ignore him he waffles a lot of rubbish. The cards are fine and all 4080/90s from palit are all over built anyways even if they don't have more phases than other cards, also they seem to keep beating the better cards too for over £2k cards like the strix etc.
Every review I have seen has actually been really good on them.
Ya, the PALIT having a, "bad", PCB should be meaningless. I love Buildzoid, but the guy vocalises his opnions on a scale of extremes. He is the poster child for the meme of, "YouTube reviewer in the video vs IRL". That said though, no fuses is just irrisponsible and he's right to call that out.
For me, Gainward might be a solid bet, though if they're sharing PALIT's PCB as they have sometimes done in other generations, then it's of course a no go. KFA2 and Inno3D are both nuke too as they're reported to be using the same fans as ZOTAC. MSI and ASUS have terrible coil whine and insane pricing. Gigabyte's Windforce looks very good. If you can get that at it's intended price (~£1800) that looks to be the best all rounder, though Gigabyte are infamous for under-stocking the UK.
So in short; Gigabyte Windforce or Gainward (again assuming it's not sharing the PALIT's fuseless PCB design)
linustechtips.com
