Yeah silicon lottery is rife with these chips so decided to try 2, unfortunately neither was specialWell, there's certainly enough connectors on the back of that PSU!
Hang on a sec....TWO i9-13990K's?!
Just cleaned up the pics as I did those last night after the England Wales game. Had one too many I thinkAh, I see. I did go back and check the motherboard pic in case I'd missed a 2nd socket! And the old system was AMD so it couldn't have been an upgrade for that. Sale or return must be a real pain for retailers.
You get used to it. I really like it. I think its a marmite situation. Useless monitor though for testing as it takes a few boots to show BIOS. Ill probably get a crappy one at Currys for testingsystem looking look but my god that curve on the monitor![]()
DDR4 hated temps over 50C if its stressed it will even start erroring out mid 40s. I like ram below 40 which can only be done with a very good water-cooling setup. My last setup my ram was still hitting 48C which is why I went with a MO-RA for the new one.I'm not sure that 50°C under benchmarking is all that much to worry about. I'm getting a reading of 41.3°C on my DDR4....although I'm not sure that it's actually changing at all. From what I've read, you might get stability issues above about 75°C so if the worst its ever going to be (benchmarking the RAM) is 50°C, you're golden. I mean, don't let me hold you back from unnecessary watercooling though....it's part of the fun![]()
Pretty sure it does have an impeller which works in any directional flow. It will be flat though, but ill keep an eye out for it. Cheers.Maybe they pre-polished the block for you...to save you the bother
Not sure it still applies to the new High Flows but the previous gen (no screen) were slightly noisy if you didn't have them flat. Just an impeller that turns and if it's off-axis the bearings aren't supporting it evenly. Just in case you find some noise while you're testing it...although I have a feeling it doesn't use an impeller any more.
   At least you can buy them now, when I started on M.2's with the 950 Pro's, you had to make them yourself.I heard Asus were potentially releasing a PCB only 4090. probably just a rumour thoughThat's a nicer length card! Damned if I know why they don't just offer them for sale bare like that for people to add a water block. Got to be cheaper to make and not add all the redundant stuff on - the heatsink alone can't be a negligible cost. You didn't fancy paying Samung £25 to stick a heatsink on for you either then!At least you can buy them now, when I started on M.2's with the 950 Pro's, you had to make them yourself.
