Consigliere
- 12 Jun 2004
- SW17
Is it possible to use an air fryer in place of a microwave? Eg warming up meals cooked the previous day such as chillis etc.
Yes, but it will dry things out, and also much harder to get it out.
Ah hmm. Get it out as in the container?
Just thinking how i would even do it as obviously can't put plastic tupperware in it.
AF300UK
Large might be more ideal for a family of 4, but yes, you can get 2 x 1.6kg whole chickens in the AF300UK. Downside of the AF400 is, well... it's bigger! (more space taken on the kitchen surface)I'm on the lookout for a af400 or similar.
Never had a air fryer before. But with a family of 4. I think I should just go for a good sized one. I've heard people regret getting a smaller one down the line.
Or can you get a chicken in a af300 ?
Reddit - Dive into anything
www.reddit.com
Depends how much the family of 4 eats I suppose. We do a chicken in one side and sides in the other side, then share out of dinner and have some leftover for 2 x lunches the next day
If you're all big eaters, then I would say get the AF400 to be on the safe side.Well yeah your right, could all be big eaters
Do you think with a chicken in one side, then all the rest of Sunday dinner type stuff in the other side, that the af300 would be big enough for a average family?
Where it will go in my kitchen I have a slow cooker. That 40cm wide so I think space is ok. But obviously I don't want a oven size machine on my kitchen side hahaha
You can't really fully load the draws because it takes longer to cook and you need a bit of room to shake things around so it cooks evenly.
Chips for example are best if you half - 3/4 fill and shake them around occasionally. Doing a chicken is fine but cooking roast potatoes, veg and whatever else in one side might be a push in the AF300
This was 1 large chicken thigh and 2 medium potatoes sliced on a mandolin with pepper for a few minutes at the end. All air fried at 200c, 20 mins
The slices are a bit thin, but yummy, more like crisps!
No probs, yeh. I do eat a lot. That's pre swim lunch.That looks big enough for us. Only me that like a big plate full
Thanks for the help
I would say the AF300 is fine ofr doing restaurant sized portions of chips for 4-6 people and a whole chicken. Restaurants where you get the small basket of fries. I personally am just a bit greedy and probably need to limit my portion sizes... but often don't
