Air fryers
Ah hmm. Get it out as in the container?
Just thinking how i would even do it as obviously can't put plastic tupperware in it.
Yeah, the container is hot.
I wouldn’t use plastic Tupperware, only ceramic or metal.
It’s hard to find something that’s the right size, you will need a towel or oven gloves to take it out.
Or….take out the grill part and use the “bucket” itself like a saucepan. Stir it half way.
Or….put the content inside some foil and wrap it like a parcel and bake it like a sweet potato.
I'm on the lookout for a af400 or similar.
Never had a air fryer before. But with a family of 4. I think I should just go for a good sized one. I've heard people regret getting a smaller one down the line.
Or can you get a chicken in a af300 ?
I've just seen the Ninja I bought for £149.99 now priced on the same site at £474.99 :eek:
Wow that is just insane :(
I'm looking at getting an air fryer but the containers seem to be deep rather than wide - can you stack food like chicken thighs for example?
Anyone got one of these?..
I’ve already got the Ninja 9 in 1 multi cooker which I’ve had since lockdown, but I only use the air fryer function and it does take up a lot of space, hence looking for something a bit smaller + the above looks perfect for kebabs (which I make a lot).
Large might be more ideal for a family of 4, but yes, you can get 2 x 1.6kg whole chickens in the AF300UK. Downside of the AF400 is, well... it's bigger! (more space taken on the kitchen surface)
Depends how much the family of 4 eats I suppose. We do a chicken in one side and sides in the other side, then share out of dinner and have some leftover for 2 x lunches the next day
Well yeah your right, could all be big eaters :D
Do you think with a chicken in one side, then all the rest of Sunday dinner type stuff in the other side, that the af300 would be big enough for a average family?
Where it will go in my kitchen I have a slow cooker. That 40cm wide so I think space is ok. But obviously I don't want a oven size machine on my kitchen side hahaha
If you're all big eaters, then I would say get the AF400 to be on the safe side.
You can't really fully load the draws because it takes longer to cook and you need a bit of room to shake things around so it cooks evenly.
Chips for example are best if you half - 3/4 fill and shake them around occasionally. Doing a chicken is fine but cooking roast potatoes, veg and whatever else in one side might be a push in the AF300
This was 1 large chicken thigh and 2 medium potatoes sliced on a mandolin with pepper for a few minutes at the end. All air fried at 200c, 20 mins
The slices are a bit thin, but yummy, more like crisps!
That looks big enough for us. Only me that like a big plate full :D
Thanks for the help
For a family of 4 I'd definitely go bigger we've got the 300 for 3 of us and I do have slight buyers remorse that I didn't go for the 400
Thanks for the help
No probs, yeh. I do eat a lot. That's pre swim lunch.
I would say the AF300 is fine ofr doing restaurant sized portions of chips for 4-6 people and a whole chicken. Restaurants where you get the small basket of fries. I personally am just a bit greedy and probably need to limit my portion sizes... but often don't
Yeah sounds like me :D
