Will check when home, 1 in tier 2 of Black Mous. I think it's the one were you have to exfil with another operators gun.Is that new? Which tier of quests?
Don't recall seeing itSent you an invite the othe night, you blew me out.
FYI, some of the DMZ missions are bugged and cannot currently be completed.
Ah that one, keep an eye out for the supply drops. Normally 1-2 from them. Maybe crack some safes.Ah I've not got to black mous yet, still need to extract with 6 kill streaks.
I'm on for that. I've had about one good squadmate in the last week, he was nuts but he was great fun, and knew his way around the map too. I've given up on the randomers, they are virtually all hopeless and just get me killed. I'm doing better now solo although when you spawn beside two squads, there's not much hope - which is ridiculous on such a large map. Game still feels a bit buggy but when it's good, it's great.Anyone fancy squadding up for some DMZ missions? Played with a couple of random squads recently with comms and the experience was considerably better than solo!
I mainly play on Xbox but also have WZ installed on steam, with activision IDs and cross play it should be easy either way.
I hope so!Apparently an update was released last night for PC crashes. Not tested it yet though.
Ah! Realised I've never shared this before.Thanks @t2na, don't think I have you added as a friend though. Will be jumping on a bit later, about 5ish.
Tested it today and it is still crashing although slightly less often. So annoying when you lose everything and your specific weapon that you need for a mission is on cooldown too.Apparently an update was released last night for PC crashes. Not tested it yet though.
I've had that once playing MW2... Only time it's ever happened!Just had a nasty crash that rebooted my PC. Never had that before.![]()
Well it happened today for me, hope its not linked to the new patch. Or that Windows update.I've had that once playing MW2... Only time it's ever happened!
