My advice is if you can afford the purchase wait until it turns up and give it a try , it will blow the 3080 away performance wise and as long as you are not cpu limited will be over a 100% uplift in native performance over your 3080 .... at your resolution it will smash all games with raytracing or notI currently use a 3080 FE 10 GB. It meets most of my needs at 3400x1440. I was keen for some much higher framerates with ray tracing in newer titles though.
