They changed run from the A button to pressing and holding the right stick. You can change this back to the old behaviour in the options. However, I noticed that sometimes Geralt can get stuck for a split second when changing direction which feels like lag, I don't know whether this intentional or not.Even the controls are now borked. Using a controller (as I always have) I can't get above a slow walk.
EDIT - and AutoHDR doesn't work properly! There's no native in game HDR option which I was hoping for - Guess they couldn't be bothered implementing something as easy as that! I mean the game's only been out for 7 years. But at least AutoHDR worked before, now there's no AutoHDR message pop up and you can't adjust the slider in the Win+G menu - so it's not working. Pathetic.
Does nobody bother to test anything anymore? Seriously.
These days I find myself playing more and more old stuff that's been 'sorted out' and updated by the community. Play the Mario 64 Render 96 fork with raytracing or Zelda 64 PC Port. Absolutely sublime.
It will be sort of amusing (in an angry sort of way) if lazy developers just rely on DLSS 3 to overcome the CPU bottlenecks brought about by their rubbish coding skills. That's not how I thought DLSS 3 would be usedAll in all I kind of expected this. Nvidia features always require the latest card of the time to be playable from physx to hairworks to gameworks. Now DLSS 3 seems to be needed for the CPU bottleneck in this.
and if PC gaming at decent framerates is restricted to those who can spend over £1000 on the latest graphics cards then it will surely die very quickly.I've been switching back and forth between it because I just cant make my mind up, on the one hand, I like the closer immersive angle but on the other I am used to my character being central on the screen in ARPGs and MMOs and I find it a little jarring when the character is off to one side in this genre.The camera angle makes such a huge difference. You actually feel like you're truly part of the world now.
GOG galaxy is my main launcher of choice, nice seeing everything I own in a single spot - yes it does open another launcher dependent on the game you play but it's a good way not to forget about stuff on lesser used platforms.Gonna give this a try, it was £7 for the complete edition on GOG so figured why not. Donwloading game now. Forgot how neat GOG was, no drm, direct download of the game without a portal/store app. Nice.
Well I waited 18 months for this update. Downloaded the 50Gb update and it now refuses to start. Some weird error that mentions the PS5 and multiple XBox’s.
Verified the files, got the launcher pop up, clicked on the start button and then received the same error as above.
No idea what’s up with it and I’ll probably try to figure it out tonight but I’m more than a little disappointed after waiting all this bloody time.
