I’m sure re-disable bar is enabled but I’ll have to double check.Have you made sure you've got resizeable bar enabled on the older system?
I checked and re-sizeable bar is enabled!I’m sure re-disable bar is enabled but I’ll have to double check.
Thanks to all who have replied to this thread trying to help me!
Hmm that’s odd.What psu are you using on the bedroom PC?
Reason I ask is because up until recently I was running a 4090 with a 9700k on a 4k Oled and it was buttery smooth playing everything except Red Dead Redemption 2 and Assassin's Creed Odyssey, which had problems with stutter. I knew when buying the 4090 that my psu may not be powerful enough but I decided to give it a try first before splashing out on a new one. But when the stutters appeared I didn't think twice about upgrading the psu, which completely sorted the stutter issues out.
I've since upgraded to a 13700k and to be honest at 4k there's next to no difference to the 9700k in any of the games I play.
So yeah, there should be no reason a 10700k should bottle neck a 4090 running at 4k, to the point where it's causing any issues with stuttering, not if a 9700k doesn't anyway.
No my GPU is an MSI Ventus. Also I managed to eliminate most of the stutter by capping the FPS to 118 frames. Now I just have a lower FPS than my 12700k system.i am having exactly the same issues at 4k with rtx 4090 and 13900k. i replaced the mobo and it did not help either. get these really random fps lows which cause stutter for me on my lg oled c2. mine is the gigabyte gaming OC. is yours?
In Nvidia control panel make sure that preferred refresh rate is set to highest available, I had similar issues with an lg c1 when it was set to application controlled.i am having exactly the same issues at 4k with rtx 4090 and 13900k. i replaced the mobo and it did not help either. get these really random fps lows which cause stutter for me on my lg oled c2. mine is the gigabyte gaming OC. is yours?
hello sorry for the late reply - i have it capped at 118 or 117fps - i just got rid of my gigabyte 4090 and got a PNY 4090 and stuttering still occurs. i am using kingston fury beast ddr5 5200 CL 40 or i prefer using 4800 but CL38 which is what it is set at now! before this i tried the 12700k and 13700k and now i am on 13900k. even with this new gpu i picked up today i still have stutter/huge fps lows in some games from 117 down to 23 or 55 and it stutters. i honestly have no idea what the issue is as i have rebuilt the entire system now. everything is new... fresh windows install as wellNo my GPU is an MSI Ventus. Also I managed to eliminate most of the stutter by capping the FPS to 118 frames. Now I just have a lower FPS than my 12700k system.
What CPU were you using before you got the 13900k?
You really shouldn’t be getting any stutter with a 13900k. Are you using DDR4 or DDR5 RAM and what speed, how much CL? Also what motherboard are you using? What size is your AIO? Are you running the AIO on default fan speeds or custom fan curve?
I live in an apartment so that’s not really possible to be honest. Not sure how that would work though! I guess you mean for grounding? Should be grounded from the mains though!Have you tried moving the PC downstairs?
I am actually using a 13900k now as well. Same Issue as the OPI struggle to believe that a 10700k would cause this at 4K, at least to this degree anyway. There will always be a difference between them. Are you sure there aren't any other programs running in the background on the other PC that could be using CPU resources? What does HW Monitor say in terms of CPU and GPU usage when playing games on the two machines?
