got my DWF ssetup. I get a message in nvidia control panel saying this dissplay is not a gssync compatable display, also playing cyberpunk at the moment to test hdr and when panning really slowly, I get blur on people and cars.
I am confused. If it allowed you to enable these, then it must know what monitor type it is. It doesn't give you options that are invalid.
Do you mean the bit that says "Selected Display is not validated as G-Sync Compatible"?
That message only appears if it recognises it as freesync. It says the same thing with many monitors, including mine. I don't think it's anything to worry about.
I am not even sure what the final option does "enable settings for selected display model". I just discovered mine was unticked, but Freesync is working fine.
This is how it looks for me (RTX 4090 with v527.56 drivers). I can enable G-SYNC, however there is a message stating that the display is not validated. I had assumed that's because this is a new model. It seems to be working fine though. Windows correctly recognises it as a FreeSync Premium Pro display.
