- 22 Oct 2012
- The Moon
Is anyone using this as their primary display with non-gaming tasks too or opting for a dual-monitor setup?
Do you set HDR in Windows to or let the monitor do its thing?
The DWF isn't does it matter? I just got it and I have a nvidia card, just tried out doom eternal looks incredible.got my DWF ssetup. I get a message in nvidia control panel saying this dissplay is not a gssync compatable display, also playing cyberpunk at the moment to test hdr and when panning really slowly, I get blur on people and cars.
I have the DW, my work laptop is plugged into HDMI and I use it all 8.30 to 16.30 every day. I swap to display port for my personal PC. I use my old 27" 1440p 144Hz IPS monitor as a secondary screen in both casesIs anyone using this as their primary display with non-gaming tasks too or opting for a dual-monitor setup?
I use it as my primary monitor for both work (mainly coding with some very occasional design work) and gaming. I've still been very happy with it. After using BetterClearTypeTuner I got the text to a point where I can notice the issues in very specific scenarios still but for the most part I've gotten used to it. Not seen any burn in so far either.Is anyone using this as their primary display with non-gaming tasks too or opting for a dual-monitor setup?
That's good to hear. I tend to use scaling in Windows and have seen some reports that this helps. I tend to do 30% gaming 70% other tasks so had some concerns that it might not be the most sensible choice haha.
The DW has the G-Sync module and the DWF is G-Sync compatible. Search both model numbers on Youtube and watch the reviews from Hardware Unboxed for a complete rundown.Gents, i have just seen this deal listed on another site, im running an 3090 but cannot see this listed as Gsync or compatibal, however it mentions VESA.
Can anyone confirm what the score is will i be able to use the Gsync compatibal options with this screen?
E
you should be able to have an option that says 'g-sync compatible' and you tick a box. I know what others have said but if you can't then that is poor form on dell's part. Even my older freesync only model can be ticked in the control panel.got my DWF ssetup. I get a message in nvidia control panel saying this dissplay is not a gssync compatable display, also playing cyberpunk at the moment to test hdr and when panning really slowly, I get blur on people and cars.
Ok, so my issues so far. The VRR flicker on the DWF or whatever it is causing it, is so poor, it was the same on my DW when I had it. HDR 400 mode on the DWF is not as good as the DW's. Unless I'm mistaken on this part, the text on the DWF is way better than on the DW. I still use better cleartype tuner and still have it at 2200 contrast, so there's no setting difference, the DWF is better to me, not even close.
You seem to be having a lot of problems there.
What video card do you have?
I do, Ive enabled it in D3D settings and also gsync settings.you should be able to have an option that says 'g-sync compatible' and you tick a box. I know what others have said but if you can't then that is poor form on dell's part. Even my older freesync only model can be ticked in the control panel.
2080Ti
