Holy hell, you guys need to check out a program called : Color Control . 8.2.0.0 for windows 10/11 :
https://github.com/Maassoft/ColorControl
you can do a help of a lot of customization with this program
and a lot of stuff has been added for LG OLED TV`s where by for instance... you can force stuff thats greyed out on lg tv`s in picture settings ect ect and calibration ect ect...
also has a awesome feature where you can make the tv turn off when you turn of your pc or turn on when you turn on your pc or make the tv go off when entering standby ect ect lots of features...
and if you want to get even more technical though i wouldnt advise it you can also get into the OLED tv`s service menu using it....
it even has a great feature that i used to get rid of dithering issues in videos, yo can select different dithering options for instance,,,,
go watch a netflix program called the recruit and put it on season 1 episode 2 at round 20.24-25.24 make sure you use the native tv`s netflix app and look at the back ground walls when there all talking around the desk.... the default setting in windows to use for instance well for me was : Bitdepth 8 with spatial dynamic, but if you change it to 6bit-temporal the issue with the what looks like banding or dithering on the wall vanishes and everything is crystal clear...
anyway there are lots you can do with this program, also it has built in nvidia inspector and game modes you can add aswell
anyway another great awesome program i have found for people is a program called : Auto Actions :
https://github.com/Codectory/AutoActions/releases/tag/1.9.19
this program can be used to launch programs and windows apps into what ever mode you want for instance,
you can launch a game with what ever resolution and refresh rate by adding it to the program and if its hdr compatible you can add HDR tick to the program and when ever you launch that program it will launch in what ever resolution you chosen aswell as activating HDR and you can set the program to deativate and change resolution back to normal after the game closes down....
you and do other things with the program also, i use this program cause sometimes the auto hdr launcher in windows 11 will only enable hdr for some games and not others so this program does it for you all the time on what ever game requires it you just add it and presto, it also works with apps and windows apps so for instance you can add the built in windows netflix app to it so when it launches it activates hdr on the tv and deactivates when closed
Both programs are Free to use.. anyway those are my top 2 programs for people with LG OLED`s with using them with PC
