- 25 Nov 2005
So I guess Russian hypersonic missiles do what they're supposed to do
How many Soviets did the Soviets kill?
Fewer people, and over a longer period.
2 million in the Gulag, maybe the same in various purges, 7 millionish in the famines. That's from memory, so I could be wrong.
Aside from the executions, most of those weren't strictly intentional, they were rank incompetence and bureaucratic stupidity. Dekulakisation was probably the direct cause of the famines, for example.
To be fair, those people aren't any less dead.
16 Days in Berlin Trailer (Battle of Berlin 1945 WW2 Documentary)
Watch 16 Days in Berlin at: https://nebula.app/16daysinberlin16 Days in Berlin is the most detailed documentary about the Battle of Berlin. Follow the battle...www.youtube.com
really good documentary series about the last 16 days of ww2
After WW2 UK and US should sort the Russia out.It was done to avoid upsetting russia. Yet another time they were capitulated to.
$1 million dollars each....owchNot even hypersonic
A Kh-22 was used, it flies at 80 thousand feet and Mach 4, it holds a 1 ton warhead that's meant meant to be used to destroy aircraft carriers not apartment building.
The Ukraine's don't have anti air system that can intercept that, they need the Patriot for that and they haven't arrived yet
You're getting locations mixed up, the Kh-22 was used on apartment building in Dnipro after the strike on KyivA Kh-22 was used, it flies at 80 thousand feet and Mach 4, it holds a 1 ton warhead that's meant meant to be used to destroy aircraft carriers not apartment building.
Hope I'm wrong but that might only be initial. Huge part of a large apartment block completely collapsed. Whether intentional, incompetence or they were just judged collateral makes little difference to the dead. It's happening every time and there's just zero excuse. Those in power in Russia need to be held accountable.Dnipro city took a battering today:
Nine dead, a 15 year old girl among them
64 wounded - 59 hospitalized.
Hundreds of people without homes. Immeasurable grief and suffering.![]()
Might as well, we're well underway of the process of upgrading to the AH-64E spec, gonna take a hell of a lot of training for the UKR pilots though I'd suspect. Its hardly a mount up and roll out type of aircraft.UK is really stepping up, story being posted by uk media
You know fine well that Russia has indiscriminately targeted civilian's from day one.
They knew what they were doing, you knew what they were doing we all did so you can take you excuses and put them where the sun don't shine.
Rroff said:Yeap I 100% agree with you there, but they also don't use their very limited selection of "advanced" weaponry to do that, they use arty, unguided 122/240/300mm rockets, mortars, tanks etc to do that, they leave their advanced missiles for things far behind friendly lines like power stations, military buildings etc rather than a block of flats which is just a waste of a missile "if deliberately targetted".There are many in Russia's command who still favour intimidation tactics and using them against civilians - though I largely agree that for the most part Russia is aiming cruise missiles and the likes against military and infrastructure targets but they certainly aren't against indiscriminate targetting of civilians.
How is it going to end?Wow just what I wanted to see and about time throw everything you got time to end this conflict.
