- 1 Oct 2020
How do you know if someone has an Alienware QD-OLED monitor?
They tell you.
They tell you.
Happy with my display thank you very much. It is arguably one of the best monitors money can buy. Only way I change it is if they release a 4K QD-OLED.
Amazing as the local system issue and it works fine on my system card gets played many times with AMD hardware and software over the years when a person wants help and one has to be subjected to blaming, gaslighting and trolling.
But remember, "fine wine"
Or wait, better yet, "*those review sites are wrong as I can get 20+% performance with my setup"
Showing that the issue is therefore not the gpu...setup consisting of the best of the best for every component, highly fine tuned, liquid metal cooling, with AC cooling on the system, with a fresh install of windows for every benchmark done
65" QD-OLED says you can tell the difference, when you game on one, come back and tell me you can't see the difference between low Res and high Res assets.![]()
Yes, the main benefit of DS for PC gamers will be how much CPU % it frees up, the rest is mostly irrelevant.i found something interesting
GPU DECOMPRESSION AND RTX IO
Decompressing assets on the GPU is still being worked on by Microsoft and graphics card vendors. Nvidia calls their GPU-based decompression API “RTX IO”. This is not currently available and has no confirmed release date as of today. Once this feature is released and implemented into games, assets will be able to be copied from system memory to VRAM in a compressed state, where they will then be decompressed by the GPU. However, the compressed assets must still be loaded from storage into system memory via DirectStorage first. The CPU will still handle these IO requests. The only change is that the CPU will no longer have to handle decompressing the assets.
Reddit - Dive into anything
www.reddit.com
Yes, QD-Oled is outstanding, could have kept the money and got a 4090 with change back when they released, glad I never as this is the best upgrade I've done in years.That's not a monitor. Lol.
You got one?![]()
Nice. But like, do you use it as a monitor bro?
Vram requirements are going to be impacted as well. As the reddit post suggests:Yes, the main benefit of DS for PC gamers will be how much CPU % it frees up, the rest is mostly irrelevant.
Less vram? They are going to be storing the decompressed and the compressed textures at the same time. This is more vram.direct storage in the long run means:
Less work for CPU
No more decompression stutters
Less RAM needed for gaming
Less VRAM needed for gaming
But these benefits don't mean anything for a very long time - because until most gaming PCs can handle direct storage, game developers have to program games the way they have been doing which means you still needs lots of vram and ram and a good cpu
If in doubt, buy an RTX 4080 FE with 24GB for £1,199.
I donno, Narnia maybe?
Yes, it will free up some vram but imo this is a minor benefit. In general we're not very vram-starved on desktop and there's a lot of easy tweaks to adjust it when we are (on the dev side), or indeed plenty of cards to choose from that aren't low on memory.Vram requirements are going to be impacted as well. As the reddit post suggests:
Current framework: copy compressed assets on sys ram. Cpu then decompresses and pushes the output on vram
Rtxio: copy compressed assets on system. Cpu then moves them as-is to vram in compressed state. The gpu then decompresses assets in flight
To be fair it still shows 24GB on the Add to Basket page for the 4080 FEExactly. As it does not exist in this world. But judging by some of your posts you are more likely from Narnia than planet Earth![]()
