You still have to use the octopus cables, its just a angled connector, no cable comes with it.as opposed to the octopus you need to connect with a regular power supply?
anyone getting the adapter is no doubt getting a custom cable to plug into itYou still have to use the octopus cables, its just a angled connector, no cable comes with it.
dont need to bend it to fit in your casesince the failure mechanism for both cablemod and default adapters appears to be the same, what advantage would this additional l-shaped connector provide.. unless someone is trying to fit a gpu in an underspecced case which is even more irrational to begin with
i am using the default octopus cables in an atx case and the covers still pushing against them, i think people are just being paranoid - 100 euros for a single cable + l-shaped connector when it doesnt even address the actual mode of failure, idk how that can be even explained awaydont need to bend it to fit in your case
dangerous is fitting the 4090 in a matchbox, you still have some way to goI’ve just fitted my 4090 in to a Meshify Mini 2 haha.
I love to live dangerously!
You don't need an octopus, you can buy a simple cable straight from your PSU directly to the cardas opposed to the octopus you need to connect with a regular power supply?
yes simply buy a cable you will still need to bed or have issues fitting it in your case, anyone buying a cablemod adapter would also buy a custom cable to replace the octopusYou don't need an octopus, you can buy a simple cable straight from your PSU directly to the card
Not that this thing replaces the octopus ,you still need the octopus on top of the adapter...
You are the one that suggested that if you dont buy this adapter you have to deal with the octopus, which is fundamentally false since the adapter doesn't even include a cable. So you can buy a cable eitherways, why did you bring up the octopus in the first place?yes simply buy a cable you will still need to bed or have issues fitting it in your case, anyone buying a cablemod adapter would also buy a custom cable to replace the octopus
maybe go read the rest of the discussion and the other quotes instead of coming here and splitting hairs just for the sake of being obtuseYou are the one that suggested that if you dont buy this adapter you have to deal with the octopus, which is fundamentally false since the adapter doesn't even include a cable. So you can buy a cable eitherways, why did you bring up the octopus in the first place?
Im not splitting hairs, you just confused me by mentioning the octopus since it has nothing to do with the angled adaptermaybe go read the rest of the discussion and the other quotes instead of coming here and splitting hairs just for the sake of being obtuse
04:14 - Custom 12VHPWR Cable MeltsReddit - Dive into anything
www.reddit.com
2nd report of cablemod 12VHPWR cable melted MSI RTX 4090 Suprim Liquid X 12VHPWR connector while played Overwatch 2 online after used cablemod extension cable for about 11 weeks.
Oh OP is from UK.![]()
It won't have been plugged in properly...it's as simple as that.Reddit - Dive into anything
www.reddit.com
Has anyone from this forum actually reported any problems with melted cables?
