I got the same too! took a while to arrive though, so long i forgot i ordered it. In between ordering it and receiving it i put on a screen protector so now I don’t need to OG case at all, it’s pretty protected all round.I'm very happy with my case/cover- post 3396, page 170 of this thread. Pull out of bag, flip the front, play.
I've read that they think it'll be pretty much the same spec but improvements in certain areas. I highly doubt they'll make 1080p OLED. The Steam Deck is great because it's cheap.I started making a new steam deck folder getting ready for steam deck 2I recon it will be out by end of next year. Get the feeling though a 1080p OLED version that I would want won't be cheap.
Think that won’t happen as anything more powerful with a oled screen will defeat the point of a cheap handheldI started making a new steam deck folder getting ready for steam deck 2I recon it will be out by end of next year. Get the feeling though a 1080p OLED version that I would want won't be cheap.
They could still give options like they do now though no?
That would be nice if they offered a premium version as long as it didn’t mean the lower tier models suffer lower performance as a result .They could still give options like they do now though no?
Help.
I have now gone through the process of a steam support ticket and have been advised they will replace the deck.
But reason is:
I have a 64GB steam deck and bought a 512 m.2 sabrent ssd to upgrade the internal memory, 1st I tried to clone what I had on the 64Gb ssd but upon using the konsole command I kept getting not enough memory around the 7.4GB stage, so went for a fresh install and followed the instructions on how to put the recovery tool onto my 512GB Samsung usb stick via rufus and installed the Sabrent 512GB m.2 ssd into the steam deck,
booted into bios and it showed the the new Sabrent m.2 in two partians of which, one showed steamOS as a name which i found stranged and under that their was my usb stick which had the image on,
so i selected the usb stick and the next screen showed up 4 options to select, so i selected the reinstall steamOS and the problems start here, first it showed me ”error please try again“ and i have followed some videos of which people have been told to press back and keep trying to get past the error, when i finally get past that stage i get onto the other problem where it shows me the steam logo screen with ”starting the download updates” where it just hangs forever, again have been suggested to go back and forth to see if it kicks in the download but nothing, on way occasion i did get past the steam logo screen and rebooted but then gave me another error, i have tried repeating the process all of last night but still nothing and even tried a fresh reimage steam recovery but before i do that theirs load of partitions on my usb stick that i have to delete to get my full storage capacity back on the usb stick.
any help would be appreciated?
do i just send the deck back with its original 64GB ssd and wait for a new deck ?
but what happens if the process happens again when upgrading the internal ssd with the 512GB Sabrent i have ?
i have all the equipment beforehand (m.2 inclosure for when i tried to clone the original ssd)
Would it help to try and take the new sabrent m.2 ssd and put it into the enclosure and connect it to a pc to delete the two partions so that it has all of the storage available and one partion ?
https://www.flickr.com/photos/197572109@N06/shares/K7jBn9ELPB
They'll have to cater for different options and manufacture different variants. Not really viable in terms of production.
Bit pointless then or more a refresh like the Switch.I've read that they think it'll be pretty much the same spec but improvements in certain areas. I highly doubt they'll make 1080p OLED. The Steam Deck is great because it's cheap.
It would be good if it's not a major change, meaning for example they could offer the upgraded screen as a replacement part and current owners could swap out their current screen for the upgraded one without having to buy a whole new deck.Bit pointless then or more a refresh like the Switch.
They can always have a pro model that has oled screen 1080p and maybe charge £600 and I'll still bite as would many.
What size steam deck do you have?What’s a good price for a 1TB SD card at present?
I’ve got a 512gb currently in there that I nabbed from my Switch but thinking I should grab another one but go the full monty for the Deck.
Sorry for the late reply, i finally sorted it out, i used a previous recovery image and although it hanged on the logo screen for a few seconds it worked,Was it a brand new drive you put in ? I ask as I got my deck a week or so ago and first thing I did was upgrade the drive before even turning it on and everything installed smoothly and it’s been trouble free since but that was with a brand new sabrent rocket 1tb so maybe if your drive is used it may need the partitions removed first and formated before trying again .I’m no expert but give a it a try
