- 1 May 2013
- M28
del
Wrong thread?Headsets are now in the hands of all the usual reviewers. Don't know what embargos Sony has given them, but with only a couple of weeks to go it would be helpful to see some content.
If i was storing loads of emulation I think they work well as there is no noticeable difference, when I put triple AAA titled games then I think there are a few seconds delay in loading. The Sandisk Extreme might be the better speed performance but they are not cheap.I got SanDisk Ultra 512GB microSDXC Memory Card 120 MB/s, Class 10, in October on a lightning deal for £32.99 seems to work well.
So I’ve nearly finished messing around with anything apart from the games on the deck, and now i think im ready to play some games, what are the must changed settings i need to change via the performance tab before i boot up any game.
my default settings are:
performance overlay level: 1
framerate Limit: 60
refresh rate: 60
allow tearing: off
half rate shading: off
thermal power (TDP) limit: off
manual GPU clock control: off
show perf overlay in steam: off
And when playing emulation what other settings should always be done and left alone ?
Thankyou for your suggestions, sounds like this is like messing around with the graphic settings on a gaming pc, of which I just pressed geoforce recommended settings.Just highlighted 4 settings that you will want to alter game to game.
Framerate limit and Refresh rate should be matching so if you find you can only hit 40FPS consistently set both to 40 (this is the 40/40 setting you may have read about online). As an example Destiny 2 (via Windows not Steam OS) feels way better when locked to 40FPS and refresh locked to 40. Same goes for CyberPunk albeit 30/30 and Control 40/40.
TDP Limit can be reduced if you can still hit you desired FPS cap at a lower TDP thus prolonging the battery life. Can also be combined with the above to further prolong battery life (even if 60FPS is possible).
GPU clock control is one that you may find helps in a game when CPU bound rather than GPU bound. As you only have 15w of TDP available to both the CPU and GPU it can help to reduce power on the GPU side to give the CPU a little more room to breath. I found this to be the case in CyberPunk which hammers the CPU. Dropping the GPU clock to ~1400Mhz (IIRC) actually improved FPS a little and Frametimes (far more important) a lot.
You running in its native SteamOS? If so when youve launched the game push the steam button on the left hand side and then there is an option to customise the control layout.I bought one of these from CEX last week (I know more than I'd pay form Valve direct, but traded in a load of stuff and got more from the vouchers than I was going to get selling for cash) got the 256 in new condition and have added an Integral 512 MicroSD Ultimate Pro which seems to work well. So far really happy with it and considering ditching my desktop and just using Steam Deck when at home.
I've got a few games to play, setting up GOG, Epic and the like and bought Vampire Survivors which i've played loads, really enjoying it and looking at Raiden IV x Mikado remix as love those sorts of games.
Ok so they fixed it now with the update I got today when I restarted my Steam, controller emulation works fine now in NFS for example. And I can edit the controller profiles again. Also emulating the 360 controller with the ps5 controller works again.the controller emulation seems broken, many games don't see my controllers:
.Heroic Games Launcher is good for GOG and Epic. I've used this and it works great for both. Change to desktop mode and install from the discover store.Just had a Steam Deck delivered but had no time to tinker with it yet.
My PC game library is split across EA, Ubisoft, Epic, etc as well as Steam itself. What's the best way of getting those launchers on the deck?
I have a 512gb SD card on the way too.
Cheers![]()
Cheers![]()
