The 33mb security update took nearly 2 hours to install last on my Pro. Is that normal?
On the Samsung I had previously it was a couple minutes and a restart.
How is signal reception on this phone?
Yes it's annoying. Disable WiFi calling I'd you live/work in a good cellular signal area to alleviate this.Signal reception is fine on mine and so is connection to my Audi handsfree system, in fact it's very fast to connect. It's also got perfect lip sync if pushing movie audio through the speakers.
Probably the main annoyance is if on WiFi and I move out of range so it has to change to cellular it doesn't seem to go straight to 5G, but instead shows as being H+ and whilst a while back it was slow and struggling it now seems plenty fast (maybe updates sorted it), almost as if it is in 4G or 5G but just not displaying the symbol. If I tap aeroplane mode on and off it will show 5G at the top straight away. It's a bit weird.
I do find that with Chrome on the phone, sometimes when you open it the page where the website contents will be unresponsive (although the actual Chrome menus still work) and I have to close and reopen then it will be fine.
Any recommendations for a Pixel 7 Pro case?
i use a leather wallet case .cc licence money .. works well and is fully protected .. yes i've dropped it a few timesAny recommendations for a Pixel 7 Pro case?
Did you buy the fake one, Bellroy has 2 L's.Belroy if you fancy splashing out
