looks like I was close with the guess, a new WR has been set by South Korean overclocker, SAFEDISK, in R23: 128k points. The CPU was cooled with LN2 and reached 5.2ghz all core
There are things that Intel have that AMD don't that although Intel is behind in performance would be good to see AMD sort for their latest as per their expected latest lineup come September. I don't expect we will see non-pro though tbh still.That's kinda dissapointing, if they're not going to beat, or beat by much, the existing Zen3 TR then what's the impetus on AMD to get around to releasing the Zen4 TR goodness, or even non-pro TRs![]()
It isn't locked in that it will drawer more, for instance as per Puget system at stock it still pulled 374w. So well yes it is aiming for 350w, it clearly will have some tolerance.His numbers are from the wall, im pretty sure the cpu doesn't draw 500w stock. It's literally impossible since it's locked (at stock) to 350w. P cores are more efficient than zen 3 in cinebench R23.
In the video you are talking about you can see pretty clearly he manually removed the power limits. You see it right below the power draw. So he's not running stock.isn't locked in that it will drawer more, for instance as per Puget system at stock it still pulled 374w. So well yes it is aiming for 350w, it clearly will have some tolerance.
In the video running R23 at stock settings it pulled 514.684w so unless Hardware info is miss-reporting that is a good deal higher than expected but they were burst power draw between 400-500w, still well above the claimed 350w. It is also really bad at ideal compared to TR CPUs. Nothing to do with numbers from the wall though.
No at the end when doing R23 he is on a completely different system to when he was doing the overclock and the footage with Intel prior.In the video you are talking about you can see pretty clearly he manually removed the power limits. You see it right below the power draw. So he's not running stock.
Regarding puget, if they measure from the cables the difference is from the VRM efficiency. For Intel PL2 = Power limit, it can't draw more than that
Υοu are talking about 14:10 on the video right? You can tell right there that he has the limits removedNo at the end when doing R23 he is on a completely different system to when he was doing the overclock and the footage with Intel prior.
The last one he shows it pulling 400-500w showing it running stock at 2.9Ghz turbo.
So either the power limits are removed and it does absolutely nothing or its at stock because it locked to 2.9Ghz and nothing more and still pulled 400watt +.
He litereally says if you check the clock speed stock it is only 2.9Ghz and shows it, the power limits might be off but it doesn't seem to be doing anything else with it at 2.9Ghz still showing to be pulling 516.375w at the time of showing that so if it does overclock then it doesn't appear to be doing anything that is suggested to be doing at 350w other than forcing the power to be higher then?Υοu are talking about 14:10 on the video right? You can tell right there that he has the limits removed
You are correct, at stock 350w PL the ccores cant maintain 2.9ghz boost. What he meant by stock is that the cores are running at stock VF curve, and their maximum all core clockspeed is 2.9ghz.He litereally says if you check the clock speed stock it is only 2.9Ghz and shows it, the power limits might be off but it doesn't seem to be doing anything else with it at 2.9Ghz still showing to be pulling 516.375w at the time of showing that so if it does overclock then it doesn't appear to be doing anything that is suggested to be doing at 350w other than forcing the power to be higher then?
Maybe he miss-spoke but saying at stock it is 2.9Ghz, showing it runing maxed out at 2.9Ghz I don't really see it being an OC of any sort. Maybe the power limit is moved up because on the PL1 350w the cores can't maintain the 2.9Ghz boost and would throttle for some reason? I can only go from what was stated in the video though.
Okay cool so the new Intel CPU at stock power limit is bogging down and thus why worse than TR-Pro parts whilst also being more power hungry for less cores than even last generation AMD cores? I assume these new Intel CPUs are same cores as the 13 series desktop parts generation wise?You are correct, at stock 350w PL the ccores cant maintain 2.9ghz boost. What he meant by stock is that the cores are running at stock VF curve, and their maximum all core clockspeed is 2.9ghz.
The same way for example the 13900k has a stock all core of 5.5ghz but you can't get that unless you remove the power limits
TLDR : His score wouldn't be 70k and the cpu wouldnt be drawing 500w if he didn't remove the limits. I think it scores 55-58k @ 350watts or something
Alder lake or golden cove cores for sapphire rapids. Raptor cove = raptor lake.Okay cool so the new Intel CPU at stock power limit is bogging down and thus why worse than TR-Pro parts whilst also being more power hungry for less cores than even last generation AMD cores? I assume these new Intel CPUs are same cores as the 13 series desktop parts generation wise?
So other than if needing PCIe lanes and double the memory throughput then they really aren't worth it. You would need to unlock the power limit to actually get to a similar performance to current gen TR-Pro so almost double the power drawer. They don't really seem all that appealing generally for most HEDT setups then I would have thought.
If you are talking specifically about cbr23, since that's what der tested, I think these xeons are faster at same core counts than zen3. Have no idea about pricing though. The best part about these xeons is that finally, we will have cheap 64+ pcie lanes with just the entry level 349$ model, a market segment amd completely ditched, since now you need to play a couple of thousands to get lanesOkay cool so the new Intel CPU at stock power limit is bogging down and thus why worse than TR-Pro parts whilst also being more power hungry for less cores than even last generation AMD cores? I assume these new Intel CPUs are same cores as the 13 series desktop parts generation wise?
I was on about the results from the test bench we've got linked generally from Puget and how it seems Intel still got a way to go for general workloads you'd expect a HEDT system to do.If you are talking specifically about cbr23, since that's what der tested, I think these xeons are faster at same core counts than zen3. Have no idea about pricing though. The best part about these xeons is that finally, we will have cheap 64+ pcie lanes with just the entry level 349$ model, a market segment amd completely ditched, since now you need to play a couple of thousands to get lanes
Ta yeah I just wasn't sure which core being used. Useful info for future use generally though.Alder lake or golden cove cores for sapphire rapids. Raptor cove = raptor lake.
Also hedt uses mesh as ring doesn’t scale to high core counts. Mesh is notably slower that’s why desktop is much better for gaming.
Voltage wise hedt uses fivr while desktop uses svid.
The holy grail would be fivr on desktop eventually but keeping ring.
Are people moving onto windows 11 now or is it considered better to just stick with win 10 for this platform?
I asked on overclock.net too see what they're using. I get the impression there are still a few bugs with it but I'm not entirely sure. Meanwhile I found this awesome tool for win 11 if I do decide to go with that https://christitus.com/one-tool-for-everything/I’m starting to wonder about this. It’s been out a little while now.
