Poll: Ryzen 7950X3D, 7900X3D, 7800X3D
Will you be purchasing the 7800X3D on the 6th?
  • Total voters
    191
  • Poll closed .
Having gone through all of the reviews its not really. Some games as expected like the cache, some not. In the techpowerup review it's a couple of percent at 1080p in it's favour and a fraction slower at 4k. Kind of a wash really.
That's the impression I got, and what I expected.
It's not a lot better than the 13900k, but the thing is, it shows you what a 7800x 3d can do.. It will wipe the i5's out of existence in gaming with less power draw.. So sure, arguably, maybe a 13900k or a 13900ks with tapped out m max memory might end up being faster, but the lower end intel parts will be basically dead in 2 months that the 7800x3d gets released.
Yeah I get that, but I get the impression people seem to think the intel is trash by comparison? (when looking at the 7950x3d and 13900k/ks
Its worrying hardly any coverage on the 7900x3D. Either its really good or really **** in comparison lol.
but if you were building new system today , think sensible to go with the AMD offering and dont forget it uses less power and zen5/x3d still to come on the platform
I wanna see side by side and how much power each is using
The 13900k is still faster in some games, and it’s cheaper.
Anything with a lot of things happening at once, lots of NPCs or objects moving around can benefit from a decent CPU. Cyberpunk was referenced earlier, in certain places it will max out a CPU. GTA is another that can push a CPU hard, more so when 6 comes. Civilization, Far Cry, Assassin’s Creed etc. are others that need a decent CPU.
Decent CPU? Define decent in such cases? I mean the Intel 12400 is a decent or better CPU. 6 core CPUs are decent or even pretty good. I mean are you referring to decent being really high end and more than 8 strong cores?
Its hard to imagine any case where more than 8 cores has any meaningful benefit to really almost any game right now.
Indeed the only thing I would think for myself is wanting to buy new shiny things anyway in the form of a new motherboard Zen 5. Will there be any new features, faster memory support, that kind of thing unless it is all possible through the x670e with bios updates.
Yes. No need gir you to change. The value for CPU changes is low esp if you’re in 4K or gpu bound.
I haven't even built it yet, was holding off a bit just in case :) Only waiting on CPU and cooler now, sigh, should have just ordered the cooler when it was in stock.
It’s a bit silly to be honest. I know they have to test CPUs by going cpu bound but it’s misleading. For example using a 4090 at 1080p is crazy. No one would buy a 4090 for 1080p as cheaper options give you as good results.
No reviews for the 7900X3D is pretty odd with a release date of tomorrow?
Its going to be a joke/meme CPU I recon. Basically no point buying it over a 7800x3d and if you can afford a 7900x3d you may as well take the 7950x3d
This Linux benchmark from Phoronix is interesting. Less than 50% power usage and higher frames in Cyberpunk ( source https://www.phoronix.com/review/amd-ryzen9-7950x3d-linux/3 ). This is linux with a 7900xtx so might be different on Windows but very interesting nonetheless.
cyberpunk-2077-2560-x-1440-ultra-2.svgz
