Not sure why people are complaining the 4090 is too big. IMO it's a good thing
Careful Dave or the mods may change your username
Not sure why people are complaining the 4090 is too big. IMO it's a good thing - means it's quiet and runs cooler.
Very happy with my 4090 Strix. Used daily for work/play since 13th of October, settled on a 350W profile (70% power target), quietest card I've used in years and had 0 issues.
Hope the 5000 launch is as good, stock on day 1 etc![]()
I’ve got a 3060ti at the minute and quite happy with just over 100fps on Max 1440p at most of my games (MW2, Horizon Zero Dawn, Spider-Man without RT etc) - do you think I would see a massive upgrade with a 4070ti? Or just wait for another gen and get whatever is reasonable then? Thanks.Been gaming using a 4070 Ti for nearly 8 weeks now. It is amazing the performance per watt you get. These cards all run very cool and quiet (a lot better than turing and ampere). Drivers have been top notch.
This reminds me of the pascal die shrink which was just dominant.
Exactly, and they know it (hence the cash-in).This reminds me of the pascal die shrink which was just dominant.
If you are happy, then you should never waste money upgrading.
Unless it’s your hobby, which in my case it is.Buying the latest shouldn't be a hobby!!
LOL, you are paying more than last gens flagship for 15% more performance, pascal moment my ass. Who knew? on a smaller process node with huge coolers they would run cooler and quiet.. mind blown.
It's worth remembering that no existing graphics cards actually provide a high performance level with RT enabled.
The ones that come closest, like the RTX 4090, which costs £1,599 or more. It should be a relatively small consideration for most gamers.
I wouldn't expect anything less for the money you have to pay for one lol.
Anyone got a release date for the 4090ti?
jk
Well, it was in my case, but they have "priced me out" now. I can't justify the prices they are charging for graphics cards now. I used to upgrade every two years. That will probably change to upgrading never! I mean I really can't foresee a time when I have £1000 to spare to spend on a graphics card.
Console time.
Unless you are chasing high resolution hz panels then you don't need the latest and greatest, no where near.
If PC gaming has become too expensive then select a resolution to run that you can afford. Some of the ultrawides and 4k take lots of GPU horsepower. Muddied with technologies such as DLSS3 and Frame generation to chase these high resolutions and must have high fps.
2560x1440 will suit most gamers or 3440x1440 at a push. Much cheaper to run and still have decent IQ with high fps. Sweet spot apparently, cant tell the difference to 4k, RT is a waste, DLSS & Framegen is cheating.
Don't chase running high resolutions, particularly with new games on release = PC gaming affordability
Dlss for web browser video playback is now out, update to the latest driver and test with Google chrome, you can change the upscaling settings in the driver to upscale the video up to 4x the base video resolution
Some testing here https://www.computerbase.de/2023-02/rtx-video-super-resolution-test/
